B3200 Starting Hard
/ B3200 Starting Hard
I think it was injector timing. I am actually picking it up this Sat. The dealer says its all better. Apparently a common problem with B3200's. He said he needed shims to correct the timing???
/ B3200 Starting Hard #22
so glad to hear your problem fixed. i was talking to my dealer about your problem and he said that they actually had a b3200 with the injector timing bad right from the factory. kinda does seem like a common problem with them. might be some of the others b3200 here problem too as they seem to think that the sputtery starts were normal. glad to hear you are running 100% again.:thumbsup: my dealer also mentioned something about the injector pump being direct gear timed and hard to get off timeing unless something came loose. ask you dealer that if you get a chance. maybe i heard wrong too. sometimes i do get things mixed up at times.:confused2:
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
17601CFL (A59228)
17601CFL (A59228)
Case SV280B (A60462)
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
