4700 will not start
/ 4700 will not start #1
PAfarmer
Norteastern Pa.
JD CTL 319D, JD 5420, JD4700, JDM665
All I get when I turn the key is a fuel solinod click. I installed a new battery and had the starter rebuilt and neither one of those fixed the problem. Checked all of the safety interlocks. Cables check out ok with a meter. Allo fuses checked and OK. I am baffled on what to do next. The Tractor Please help if you can and thanks.
/ 4700 will not start #2
Here's what I would do, trace the wires to the ignition switch. Pull them off and touch them together to see if engine turns over. Kinda like hot wiring a car. It could possibly be as simple as a bad ignition switch. Had this happen to me on a 86 Dodge truck. Drove me nuts.
/ 4700 will not start #3
If battery tests 12+ volts I'll bet it's the ground cable. Probably where ground attaches to tractor. A volt/ohm meter may show 12 volts but the cables if a bad connection won't carry the amps for turning starter.
ok thanks . I'll try both post suggestions and report back
/ 4700 will not start #5
Does a 4700 have a thermistor?
That is a very common problem when a 4200, 4300 or 4400 doesn't start.
Try doing a TBN search for "thermistor". There are numerous threads on this subject.
/ 4700 will not start #6
That is a very common problem is a 4200, 4300 or 4400 doesn't start.
Wheres that located at and what does it protect?
Finally got it fixed. I found a broken wire coming off of the PTO switch. Poor factory crimp left me stranded for over a month. The wire was broke at the crimp but then only to be reattached to the very end of the crimp connector where the covered wire is suppose to be held as a strain releif. Factory screw up! This little gremlin has been pissing me off for 12 years now. thanks JD
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
Bad Boy MZ Rambler Zero Turn Mower (A64047)
Bad Boy MZ Rambler...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
Adams Under Truck Conveyor (A63118)
Adams Under Truck...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
