Loader Larger bucket
/ Larger bucket #41
My experiences with the L3400 and 60" bucket has left me with the feeling that for general use, they're a good match. I've come close to rolling it a couple times because a front wheel dropped into a low spot with a full bucket of earth. More weight up front might have been the difference between close and "Oh sh**."
If all I moved was manure, sawdust, or light material like that, a 66" would be fine probably. As it stands, I'm not a good enough operator (nor is my wife) to push the envelope any further. I wish I had a 60" SSQA bucket, but I've no wish for a 66"
Sean
Sean, I had 10 bags of 80lb cement mix in the 66 and it was fine, but I was not on tilted ground either. When operating on a side tilt with a gravel filled 66, if you moved too fast, it started to not feel so good. I preferred the 60 for any work where the angles were bad, and still do :) Plus the 60 will dig better. So yes the 60 is a good match for the L3400 or that class of machine, But the 66 is OK for most things, just pay more attention:thumbsup: But for a newbie.. I can tell you for sure I would put him or her on the 60 inch to learn with. The 66 is great for mulch:thumbsup: I have both, but the Kioti is a lot heavier machine and can handle its standard 66 much easier.
James K0UA
/ Larger bucket #42
Sean
SSQA is about the best thing you can add to a Tractor w/FEL. It's a great system. I'm sure you would be happy with a 60" bucket and a set of forks.:thumbsup:
/ Larger bucket #43
Interesting thread. I have a L3430 with a heavy duty (round back) 72" bucket. The short bed on my F250 is about 76" and it is always slow going trying to load it without beating it up like I did with my old Dodge. I have thought about getting a narrower bucket but haven't done anything about it yet. I never thought about shecking with my dealer to see what take-offs might be available in his yard. The bucket is a pin on and I have a thumb on it. I wouldn't want to get rid of it. Thanks for the ideas.
/ Larger bucket #44
I am looking at buying a new L3800 w/LA524 loader. According to my dealer, and what I see on the Kubota site, if you get a QA you can only get a 66 inch bucket.
The way I understand it, the 60 inch is a pin on. I wanted a 60 QA. It looks like I would have to go aftermarket to do that.:(
It is my opinion that a 60 is the correct size for most work with a machine that small. A 66 would however be better for snow removal, but would be about max for dirt work.
Bill
If you want a good heavy duty 60" bucket in a skid steer QA, get your dealer to order a TL2142 bucket. It's a 60" round back bucket that is intended for the B26, cost is $836. Should be a good option for a heavy duty bucket on a L3200/3800.
/ Larger bucket #45
Thank you , I will look into that.
Best, Bill
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
John Deere R75 (A60463)
John Deere R75...
