No roof over the deck but the patio area will have a pergola over it.
I was able to get most of the decking down, even though the weather has not been the best.I hope to get more of it done tomorrow.
This weekend I will place the beams that run parallel to the deck(provided we get no rain).
I think I will drink my morning coffee on the deck this weekend.![]()
It looks good. :thumbsup:
I'm getting ready to screw down the deck planks on my son's new tree house. What spacing did you use between your deck boards?
Are you using 4x4's for the beams? What is the span between posts?
You really need to do a google search for span tables. They list the size of lumber that you need to go a certain distance to support a load. Seeing that you are in Ohio, I'm going to assume that you get snow. A flat pitch, with snow sure sounds like you want to over build, and not cut any corners on undersizing your beams.
Eddie
The deck looks nice but I do see a few issues I'd like to point out.
The header beam over the patio door appears to be a double 2x6 which could sag over time, unless steel plate was used in the middle. A double 2x8 or 2x10 header beam would have been stronger and less likely to sag.
On the deck, I noticed that the support beams are attached to the sides of the 6x6 posts. Since the deck is close to the ground, I don't imagine it will be much of an issue, but if the deck were higher, it could present a serious safety hazzard. The proper way to support a load carrying beam is to notch the support post to accept the beam so that the post carries the full load of the beam, rather than the bolts alone.
Correct:
Incorrect:
Its going to be interesting to see how all that rain runoff and snow coming off the roof affects your deck. Have you planned on gutters to direct the water to the ends? We dont see many sun decks in the south, most folks like to shelter their house and person from the sun as much as possible. I suppose there will be a BBQ pit on that open deck area soon after it is finished.
Correct:
Incorrect:
