New Max series...
/ New Max series... #141
How come Mahindra dealers never even quote MSRP on the web? Most other dealers at least provide MSRP so you have a working ball park as to what implements and tractors will cost. It is kind of a pain in the neck forcing the consumer to make calls to dealers all the time.
Mahindra has heard you and plans to start listing MSRP on the MUSA website soon.
/ New Max series... #142
Is it my imagination or is mahindra really stepping up their customer experience lately? I've been looking at tractors for two years and reading this site for almost as long and it seems like there is a trend. Or perhaps it is because I was reading more about the orange guys until the Max series was announced.
/ New Max series... #143
Better late than never, if they actually do it, long term. As I recall, Mahindra previously listed MSRP prices on their website, but for whatever bone-headed reason, they decided to stop listing them several years ago.
/ New Max series... #144
When I purchased my Mahindra back in '06 they were posting list price. Kubota wasn't, so I had to visit a dealer to find out Kubotas' price. I almost didn't consider the Mahindra because it was priced a lot higher on line and I wasn't very familiar with the brand other than some radio ads I had heard. I would of had to get the loader for free and them some. Fortunately I had a close Mahindra dealer when I did a dealer search. I checked them out, liked what I saw and ended up getting a quote about the same price as the Kubota. Kubota was offering 0% interest while Mahindra was 1.9%. So the dealercut the price a little more to cover my interest. I still like to see some pricing on line, but you MUST visit a dealer for final pricing before you can make a decision on any brand you may or may not even have considered!
/ New Max series... #145
Hate to break this to you, but they both have the same engine under the hood. One is rated at 28HP, the other at 25HP at 100 less rpm if I recall correctly. Both are Mitsubishi S3L2. I bet they are real close in HP at the same RPM if we put them on the dyno. :thumbsup:
Dave, something enables the 28XL loader to lift over 350 lbs. more than the 2516. What is that feature, and where is it located on the tractor? The 28XL even has lower pump output. This is confusing.
/ New Max series... #146
They switched from the ML105 loader to the ML205 about the time they switched the 2516 to a Max 28. Slightly larger rams on the ML205 gives more capacity. It would surprise me if the pumps were different, but I haven't checked that.
Keep in mind that pump volume does not affect strength, just speed. Pressure affects strength.
/ New Max series... #147
Would it be possible to install larger rams on my ML106 to increase the lift capacity?
/ New Max series... #148
Back in the day, the 3015 was made and shared the same frame as the 2615, and it came with a ML110 loader. That loader actually fit fine on the 2615 and lifted about 300 lbs more I think. It did have an extra frame brace. It lifted more because the rams were slightly larger.
So yes, a larger ram would work on your loader and it would lift more. But remember when you start engineering your own "improvements" you live with any consequences.
Keep in mind that going from a 2" cylinder to a 2.25" cylinder will make about a 250 lb increase in lift capacity on your loader. And going to a 2.5" cylinder will make probably a 650 lb increase. Since the radius is squared to get the cross sectional area, this is not linear. So don't get carried away or you will break things. And a larger cylinder requires more flow to extend at the same speed, so if you mess with this, a minimal increase gives more lift and adequate speed. A big increase makes the loader too slow and you break things.
/ New Max series... #149
Thanks Dave. When you take the time to answer these questions it is truly appreciated.
/ New Max series... #150
Nice to have a dealer go beyond lurking on the site now and then to reading, participating, and answering questions. Wish more dealers would be willing to exchange info and technical knowledge. My Deere dealer has always been very helpful and i am thankful he is located only 5 miles away as i visit often for fluids filters and accessories.
/ New Max series... #151
If I am not mistaken, Mahindra is launching a new series of tractor. I believe this is a compact line that competes favorable against say a Kubota BX series sub-compact... Is my info correct?? And if it is, what is the ETA of such a machine? Any specs out there (for example, how would it compare to the 1816?). My garden tractor just broke for the last time! I am not sinking any more $$ into it! Maybe it's time to buy Mahindra #2 for mowing and yard work...
Any info on these would be great!
Thanks,
Amstaff
Negative..........
You stated two entirely different categories: 'compact' and 'subcompact'.
The Mahindra Max is actually a 'compact tractor', it would be comparable to a 'B' series Kubota, or other similar CUT tractor.
Mahindra is falsely advertising their product.
And in the case of the MAX 22..........it appears to be a 'severely underpowered' CUT at that.
My SUBCUT Massey has more power to the rear PTO than the Mahindra Max 22.............The 1860 Kubota(smallest SUBCUT Kubota makes), has the same PTO HP as the Mahindra Max 22..............at about 8 grand less money.
/ New Max series... #153
Negative..........
The Kubota BX1860 in more of a garden tractor compared to the MAX22. However, Tractor.com refers to the Kubota as a compact tractor. And no there is definitely not an $8K difference in pricing.
Tractor.com - 2011 Kubota BX 1860 Tractor Reviews, Prices and Specs
2012 Mahindra Max 22 Review
TimberXX
Gold Member
Default
I got a price in VA a few days ago.
Max 22 with no accessories for $10,500
I want to know if this is a good deal.
The other dealer near me I refuse to do business with.
Opinions? http://www.tractorbynet.com/forums/mahindra-buying-pricing/220909-new-max-series-4.html
/ New Max series... #154
Some of the comments from Kubota fans are just rediculous. I won't quote any of you directly as I don't intend to get into a back and forth, but come on guys, Kubota can do what they want, so can Mahindra. Until some official group declares just what defines a sub-cut or a cut, I think the nonsense about false advertising is just brand loyalty coming out in an ugly manner.
Mahindra has made a very compact conventional tractor. It clearly does not have lawnmower size tires or does not look like it comes from lawn mower heritage. So is it disqualified some how from this ambiguous SCUT nomenclature? It really is what people are looking for that have an acre to 5 acres. Yes it is a half step up in specs in some areas, and some people that do 90% mowing and very little loader and backhoe work might find the lighter Kubota better suited. But we feel for most applications, this defines what the market wants in a SCUT.
So sure, by Kubota standards Mahindra has muddied the waters between the BX and the B. But there is nothing wrong with that. I understand your points about Mahindra making comparisons agains the BX, when they could choose to compare to the B, but the market this tractor is directed towards is the SCUT market.
And every time this thread comes back to the top, more people learn about Mahindra and want to see about these Max models. So in that way, let's keep up the conversation. :D
We have never seen such intense interest in a new model.
/ New Max series... #155
/ New Max series... #156
So has Kubota, John Deere, Cub/Yanmar, Massey and New Holland. But none of the above stoop to false advertising as Mahindra does.
Mahindra does not make a "subcompact tractor".
And you as a 'red carpet dealer' knows this, and probably never should have entered the discussion. You appear to be condoning the actions of Mahindra Corporation to mislead people.
Honest dealers don't mislead buyers.
This was an honest statement though, "Mahindra has made a very compact conventional tractor". But it is not in any way, shape, nor form a 'subcompact'. The Mahindra Max series and the 1816/2216 are compact utility tractors pure and simple.
/ New Max series... #157
Don87,
I dare say you will get little support from anybody not drinking orange Kool-Aid for calling me dishonest and for asking me to stay out of a discussion.
Stay up on your self-righteous soap box and tell the world that someone is marketing in a manner that hurts your sensitivities.
Meanwhile, we will continue to sell the dickens out of these fine tractors.
/ New Max series... #158
Don87,
If you'll notice.......mine is red.
That's 2 mistakes you've made in 2 posts..........care to try for a third?
The specifications on the Mahindra "subcompact tractors" clearly show them to be miscategorized purposely to fool the public.
Mahindra does not make a subcompact.
You have the facts in front of you, and as a dealer, should not be pushing them as something they aren't.
This is why you should not have entered the discussion..........you know that they are not subcompacts. To say they are, and you being a dealer with the knowledge to know the difference, makes you dishonest in my book.
As I've told the others, it's like comparing an F250 to a Ford Ranger.........the only similarity is that they are both trucks.
/ New Max series... #159
Well Don, my bad on not catching the fact you have a Massey.
Calling me a liar doesn't fly, and you will not get support for that comment from anyone that knows me. Calling me imperfect, well that's not a problem! :)
I'm not coming down to your level, to do so would require personal attacks on your integrity, and that is way out of the realm of a well moderated tractor forum such as this.
207271 (A52708)
207271 (A52708)
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
Rhino SE8 Rotary Cutter (A64047)
Rhino SE8 Rotary...
(2) 330 GALLON POLY TOTES W/ CAGES (A62131)
(2) 330 GALLON...
