B7500 with 5' Bush Hog
   / B7500 with 5' Bush Hog #1
Theridge
Member
Not sure the model number but I have a chance to buy a 5' bush hog. PTO will match up but will this be ok size for my B7500 tractor? Also, check out the photo, how much do you think it is worth?
   / B7500 with 5' Bush Hog #2
Maybe, it is a little big, but depending on what you are cutting it may be OK. Some guys do use them, but it may not handle the heavy stuff well with your 17 PTO horsepower. When I had a B7500 I used a 4 footer. Also consider keeping your loader on the front for front ballast.. While you 3pt will easily lift it, the weight is stuck pretty far out there, and will start to make the front end light. Since there is not a guard on that PTO shaft, you need to be extra careful to never get near it when the tractor is running. I am not sure what it is worth.
James K0UA
   / B7500 with 5' Bush Hog #3
I have 60" KK Heavy Duty rotary cutter that I pull behind my B2920. It pulls and cuts fine, but you really need the FEL in place or it gets a little hairy on the slopes :eek:
Front end loader will stay on.
Ok Im kind of new to this but is the B2920 bigger or smaller than my B7500?
   / B7500 with 5' Bush Hog #6
   / B7500 with 5' Bush Hog #7
By the way I have a set of tire chains (front and rear) that will fit a B7500 if you have industrial tires if you live anywhere near Southwest Missouri (branson) They are used, but still in good shape. I would let them go cheap.
James K0UA
   / B7500 with 5' Bush Hog #8
My opinion is to go with a 4 footer. I feel a 5 footer on your tractor is going to want to wag the dog too much.
The one pictured is actually in alot better shape than I see them around here on CL. Real rough ones start around 3 - 4 hundred , and go up from there.
Yeah, I am thinking of looking for a 4'. Seems like the 5' may be a little much.
   / B7500 with 5' Bush Hog #10
You pull an 800lb cutter on a B2920:eek:
4' would be a much better match. But a lighter duty 5' would work, you would just have to slow down more and use caution when raising. You have HP and weight both working against you.
Price is really regional. Around me, rough ones are $100-$200. And nice units like the one pictured are in the 3-4 range. If the one pictured were around me, I'd expect it to go for ~$400-$450
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
1998 CATERPILLAR D5M PIPE LAYER (A50854)
1998 CATERPILLAR...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
2009 MACK CXU613 DAYCAB (A50854)
2009 MACK CXU613...
