Farmall M Hydraylic Lift pump
/ Farmall M Hydraylic Lift pump #1
slammer3364
Jinma 284
Hi I had a question a bout my Farmall m Hydraulic resivoir leaking. DJ 54 and kevinj sent me replys. I can see why you would see stars that unit looks extremely heavy. We got it in garage finally and took the small plate off to check it out,and have some pics. Where can you pick up a cheapie I T manual?
/ Farmall M Hydraylic Lift pump #2
At your local farm store, you can also get IH reprints off ebay.
Removal is pretty easy.
Before removal you should see where the leak is.
Thanks for reply Kevin,found i t man. @ IH dealer.Looks like it is leaking around the front resivor gasket,I guess the man. will describe how to and what tools we need,again Thanks for getting back to me
/ Farmall M Hydraylic Lift pump #4
Are you sure it is not the shaft seal???? If you open it up to replace the gasket put the seal in anyway.
2016 Ford F-150 4x4 Pickup Truck (A61573)
2016 Ford F-150...
CHAIN LINK FENCE (A64281)
CHAIN LINK FENCE...
More info coming soon (A61569)
More info coming...
NEW WATERPROOF/FIREPROOF FIRST ALERT SAFE (A64281)
NEW...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
74" X 49" TAILGATE (A64280)
74" X 49" TAILGATE...
