Farmall M Hydraylic Lift pump
/ Farmall M Hydraylic Lift pump #1
slammer3364
Jinma 284
Hi I had a question a bout my Farmall m Hydraulic resivoir leaking. DJ 54 and kevinj sent me replys. I can see why you would see stars that unit looks extremely heavy. We got it in garage finally and took the small plate off to check it out,and have some pics. Where can you pick up a cheapie I T manual?
/ Farmall M Hydraylic Lift pump #2
At your local farm store, you can also get IH reprints off ebay.
Removal is pretty easy.
Before removal you should see where the leak is.
Thanks for reply Kevin,found i t man. @ IH dealer.Looks like it is leaking around the front resivor gasket,I guess the man. will describe how to and what tools we need,again Thanks for getting back to me
/ Farmall M Hydraylic Lift pump #4
Are you sure it is not the shaft seal???? If you open it up to replace the gasket put the seal in anyway.
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2002 Bobcat 863 Compact Wheel Loader Skid Steer (A61572)
2002 Bobcat 863...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2009 STRICK 53X102 T/A DRY VAN TRAILER (A59912)
2009 STRICK 53X102...
30" X 11' ADS DRAINAGE PIPE (A64281)
30" X 11' ADS...
