my deck/patio project
/ my deck/patio project #1
Chooglin
Gold Member
NE Ohio
Bolens 1468 - MF GC2310
I know how much I enjoy following some of the projects that have been posted,so I thought I would share mine.
I started this project last summer,when I installed the french doors in the back of the house.
This year I am going to get the deck/patio finished (with the help of my dad)
just to catch everyone up on where I am with the project,I have the ledger board hung,layed out where to drills the holes,drilled the holes tuesday and mixed the concrete yesterday.
I will be setting five of the eight post today.
I will post pics and comments as I go.
short video of my GC2310 drilling the holes.
[ame=http://www.youtube.com/watch?v=De--bDdkiF8&feature=channel]GC2310 post hole digging - YouTube[/ame]
/ my deck/patio project #4
Just wondering why you decided to go the ledger board route??
Personally, I dont like the ledger method. I like setting posts next to the house. Several reasons. (I am sure there are also good reasons to use a ledger)
First, where I live, anything attached to the house has different (more strict) codes to follow.
Second, If it is an "attachment" to the house, homeowners insurance goes up a tad. Not much but still...
Third, I dont like the idea of peeling siding off and risking NOT getting it sealed back up good causing rot to the house.
Not saying you are doing anything wrong, because lots of decks are built that way. I just never understood or heard a good reason. That is why I have always set posts and had a "free" standing deck.
Good luck with the build and keep us posted with pleanty of pics:thumbsup:
/ my deck/patio project #5
The reason for the ledger board is because that's how it's always done on This Old House.
/ my deck/patio project #6
I still dont like it. And for the cost of the ledger board + proper fastners + joist hangers,
I can set additional short posts next to the house, and attach a headder to it, and just let the joists set on the header:thumbsup:
/ my deck/patio project #7
Using a ledger board is easier. Less holes to dig and less concrete to deal with.:thumbsup:
Third: I dont like the idea of peeling siding off and risking NOT getting it sealed back up good causing rot to the house.
First:I have no problem with following the "codes"
Second:my insurance on my vehicle goes up when I buy new also (its an improvement).
Third: provided you flash the ledger board properly,there should be no concern of rot.
I hope you dont take my comment as being a "wise ***", I am just being realistic.
I just feel that it makes for a more rigid deck and it is much easier to hang a ledger board instead of drilling and setting an additional 5 post.
/ my deck/patio project #9
No I dont think you are being a wise @$$. And I hope you didnt take my comments that way either. I was just curious, cause I never new why soo many people choose the ledger board method.
I guess for me, a few more holes and a few more bags of concrete is easier than dealing with vinyl siding and flashing. But for others and you, the ledger may be easier.
5 of the post are in.the 3 emmpty holes will be
getting 3 more 6x6x16 post, that will be for the pergola
over the concrete patio.
Tomorrow I will be removing the top soil under the deck area
to lay plastic and gravel,then I will be hanging the support beams.
If time allows,I hope to hang some of the floor joist.
thats all for today.
/ my deck/patio project #11
Going to be a nice size, are you planning to step the levels at all or keep it all the same height?
The deck will be all one level with a set of steps going down to the patio.
/ my deck/patio project #13
Are you going to have a roof over it?
I want to do about the same thing, but I want to run a roof over it perpendicular to our main roof's ridge line and I want the deck/patio to have the same type roof as the house has rather than a flat roof.
My thinking is if I tied it into our house's roof I could possibly vault the living room's cieling at the same time (likely a pipe dream though).
Any thoughts on this.
PS it looks great.
/ my deck/patio project #14
question
did you coat the 6x6 posts with anything before encasing in concrete?
will the posts last a long time if sitting underground in concrete?
I'm in the process of planning a deck that I will then mount a quonset hut onto, and am trying to research the best procedure for the foundation.
PS it looks great.
No roof over the deck but the patio area will have a pergola over it.
vaulting your cieling would be nice,my sister and her husband did that to
there house 2 years ago...............it came out real nice.
/ my deck/patio project #16
PS it looks great.
I am doing basically what you have in mind. I have a workshop (30x40) with an outside concrete slab 20x18. I have spent many years working out there in the hot sun. So I am adding a roof that will tie into the shop. From the air it will have a T shape. It will have 4/12 pitch to match the shop roof. I set my last support pipe in concrete today. Debating starting a thread on it and a shed I am going to build.
My limited knowledge about setting wooden posts is that there are 2 recommended ways. One is pour a footing for the post and use a post anchor to attach the post to the footing. The other is dig your post hole and pour about 4" of gravel into the hole, level, set post, pour another couple of inches of gravel then concrete. Also make the bottom of the hole wider than the vertical sides.
I have use both methods. For a flat roof over my back patio I went with anchor method. For a carport off of the work shop I set PT 4x4 in concrete. That was in 1990. I have not experienced any problems.
question
depending on your codes,you may not be allowed to concrete around the post.
In my case,I drilled a 40" hole and mixed 1, 80# bag of concrete per hole and poured it in the hole.After it dries, you drop the post in the hole and the concrete acts as a footer.
I have heard of people using a rubber type boot around the post before placing it in the hole.
They should last 25 years + without a problem.
Moving along
I got off to a late start tonight (my helper was late getting to my house).
but I did get quite a bit done.the support beam is in and some of the floor joist.
Tomorrow I will be laying down the plastic and gravel and setting the rest of the floor joist.
They are calling for rain Sunday ,so I will get the day off :)
that is all for today.
I built a porch on the front off my house back in 1994,and I did build a roof over it.I set my post to our codes hear in my county.40" deep hole with 8" of concrete in the bottom.
I vote for you starting a thread on your project,I love following threads like this.
/ my deck/patio project #20
Using a properly attached ledger board will give the deck more strength then a free standing deck. The mass of the existing building creates a solid, unmoving side to the deck. It just about eliminates racking on decks that are just a few feet above grade, and there is no twisting like you see in free standing decks. You will have a stronger deck, with less material.
While your points of having to deal with inspections and insurance have some validity, all that really means is that they are going to make sure that it's built to a minimum standard.
Free standing decks are used on mobile homes around here because there isn't a good way to secure a ledger board to the side of them.
Eddie
2018 Ford Explorer AWD SUV (A66738)
2018 Ford Explorer...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2023 Land Pride...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
2002 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2002 FORD F150...
