New 8560 CAB
/ New 8560 CAB #1
2000CBR929
Millsap, Texas
Case IH Farmall 95C Cab 4WD with Loader
New member here so hello to all!
1. I have a new 8560 CAB 4WD with about 40 hrs on the clock, and the other day while grading a newly leveled pasture with my 7' cannon sp? grader in 3 medium I was getting high temps alomost to the point of overheating. The machine was loaded pretty good and I had the rippers in about 6", but with 83 HP I find that somewhat odd. I have only used it to haul around round bales and move a few hundred yards of dirt, and at a glance the radiator and intercooler look clean as a whistle. The overflow bottle was on the low side, but all else seemed fine. The conditions were dusty, and the temp here in Texas was in the high 80's with the cab temp hovering around a balmy 72. The only other odd thing was during the initial start up that morning I noticed the annoying blinking emissions light flashing so I cleaned the air filter for good measure, and went on to work. Later in the day it was flashin again. I can't imagine what causes this and have read is is more of an annoyance than anything.
The only pic I have so far
/ New 8560 CAB #2
2000CBR929,
With 40hrs I'd definetly would be on the phone to the dealer and get it documented by them at the very least. I'd also make sure that at your 50 hr. service all issues are addressed. My 5530 had intial issues - blinking ecg light and a hydraulic leak. Dealer took care of it on the 50 hr service. It's warranty work.
Great looking 8560. Need a few more pics in action.
idaho2
/ New 8560 CAB
Thanks Idaho. My dealer is supposed to be calling me with info. I typically do all of my own service, and have to haul it an hour away if there is something I need done so I was hoping to have an easy fix. That darned light was blinking on my 6530 too. I would hate to see the sirens and lights on a tier 4 machine.
/ New 8560 CAB
Just got off the phone with the dealer and he is certain it's the dust. I half way believe him since that is mostly what I have done since I have had the machine, and even the drains for the A/C were clogged with dirt the other day to the point where they were not draining out of the tubes, but the vents. I got off and pinched the tubes and condesate just pourd out of them for 5 minutes. He say to blow out the intercooler, the A/C, and the radiator every chance I get to prevent the overheating. Says last year in our drought his phone was ringing off the wall with the same issues, and always dust was the culprit. He also says the same for the blining light which confirms what happend the other morning when I blew out the filter and the light went off. I guess I will have to be more diligent about that when it's hot and dry.
/ New 8560 CAB #7
2000CBR929,
When Mt. St. Helens blew, the ash was so fine it raised heck on all vehicles cooling systems. The work around was a "pre" air cleaner attached to assit in cleaning the air from the fine particulate. Could this be a solution for your present situation? Just a wild thought.
idaho2
/ New 8560 CAB
You might have something, and I will look into it. I still find it a little hard to believe with no more dust than I blew out that it was THAT clogged. I mean it has an inner filter as well. Our construction equipment takes way worse of a beating than that, but I will try once again and make a better effort to get it cleaner.
/ New 8560 CAB #9
If you would have dropped down a gear, it probably would have cooled down some. It's not that the tractor won't make the pull, but it is a lot easier on it to drop down a gear and raise the rpm if you need to go the same speed. That is actually moving pretty quick to have the rippers in the ground. What rpm are you working the tractor at?
/ New 8560 CAB
Around 17 to 1800
/ New 8560 CAB #11
Around 17 to 1800
Same as what I normally run my 7520 at. But that is a little low in the rpm range with much of a load on it. As the load gets to be greater, I have found that I need to start bumping the rpm up. It would also make a difference with how hard your ground was. I have my 7520 ballasted to about 12,000lbs and my Gannon will stop the tractor if the ground is right.
/ New 8560 CAB
Right on, and it did load up on occasion. The 8560 with loader, and Cab weighs in at over 11k without ballast of which I have none. I have already torn up one "Triangle Hitch" similar to a delta with the box blade full thanks to a hidden stump. She's heck for stout, but was a little fickle the other day.
/ New 8560 CAB #13
How about 10,212lbs per spec sheet. Did you weigh it? Just wondering how you arrived at over 11k is all.
Pictures of her working would be great to see. :cool:
/ New 8560 CAB
I stand corrected....Apparently I poked a couple extra buttons with the calc when I originally added the weights. As equipped I have it with Hydro top link, Traingle Hitch, and Bucket which I may have mistakenly understood wasn't in the shipping weight at around 10777. Either way it is quite heavy when compared to some of the other machines as is.
/ New 8560 CAB #15
I believe that it is one of the heaviest tractors of it's size and is one of the reasons that it works so very well. :thumbsup: Now you need to get a hydraulic side link and your grading will be all that much better. ;)
/ New 8560 CAB #16
Most excellant tractor. We need more photos of it in action.
hugs, Brandi
/ New 8560 CAB #17
I also have an 8560 that overheats. there is a VERY fine air filter in front of the rad, like the one in your house window AC unit. we took that out and it helped some but not enough. we blow it out every morning. dealer knows nothing about it. does anyone have a fix for this?
/ New 8560 CAB
Yes.......The fix I found for it after cracking two front wheels, constant overheating, several antifreeze leaks, and such was to replace it with a 2014 Case IH 95c. Problem solved. I loved the tractor, the loader was second to none when comparing other machines, warranty was great, and tractor weight was serious, but I had to have something I didn't have to constantly wrench on. Problems I had were overheating (partially due to some diode that made the machine think it was hot) Fix was replace the dash which included the updated diode er whatever they called it, and a bunch of seals installed around the hood, and body work that directed the air flow across the radiator better. I still had issues with it. I couldn't keep the air filters clean. That thing was like a vacuum, and the A/C air filters on the cab needed to be blown out two to three times daily. As an open station model I don't think any brand could touch it, but as a cab model with all that is required to run that beast at full tilt, and have it reliable they have some work to do. I don't mind working on my stuff, just not every time I get ready to use it, and walk out in the garage and notice anti-freeze on the ground from yet another loose hose or bad clamp, or that nasty sticky throttle cable (due to the injector pump return spring not being properly adjusted), and last but not least the smallish fuel tank. No 10 or 12 hour days at PTO speed for that rig. I felt like I was constantly filling it up.
/ New 8560 CAB
Call John with Mahindra Warranty. At least that was the guy the last time I went through warranty work. He was working DFW, up into Kansas, and such and explain your issue to him. He was the one that supervised most of the fixes they implemented on my machine, and was aware of the issue at the time on another tractor in Kansas on which they tested the repairs. Successfully on that machine? I don't really know. 1-832-544-6836. Hopefully this helps!
/ New 8560 CAB #20
At 50 hrs you or the dealer will have to reset the computer on your 8560 after engine oil change, find fuse panel on left side of steering wheel, there is a blank hole, pull fuse and place it in blank hole with engine off, now turn key on for a minute, turn key off and replace fuse to original position and start engine... Between EGR canister and valve cover is a line that was dry rotted from factory that also cause the emission light to periodically flash, replace it.... High volume compressed air on a long reach blow tube to back blow out radiator should take care of heating issues... On our 6500 we had to build a battery box on top of front weight to allow more air flow through radiator to correct overheating issues with it... Mahindra dealer all the way to Tumball Tx were of no help on resolving issues that they will deny are existing
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
2015 Freightliner 122SD Truck, VIN # 3AKJGND68FDGH1824 (A61165)
2015 Freightliner...
LandHonor LHR-UBF10 10in Utility Blower Fan (A60352)
LandHonor...
2017 Chevrolet Cruze Passenger Car, VIN # 1G1BE5SM8H7151252 (A61569)
2017 Chevrolet...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63118)
FRESHLY...
