42" deck - left blade not cutting
/ 42" deck - left blade not cutting #1
79lilred
Hot'lana, Jawjah
Deere/Scotts
Have a Scotts (Deere Sabre) S1642. The left blade cuts so badly you would think I have the blade on upside down (yep, been there done that before!). Yard looks like a 2-bit haircut when I'm done if I don't go over it for a second pass.
Have sharpened blades and even installed brand new blades. Love the mower otherwise.
Any ideas?
thanks!
-steve
thanks for the reply, Pete!
As well as checking to see if the blade was installed correctly, I did verify it was turning in the right direction also.
Can the quill assy or the belt itself be the problem? I installed new quill assemblies some years ago - 1 came with grease fitting, 1 did not - I installed grease fitting on that one and keep them full of grease.
/ 42" deck - left blade not cutting #4
sounds like the 2 quill assemblys might be different ???
is it possible you've got different cutting height on the 2 blades as a result ?
or perhaps the pulley is sized for a wider belt ?
I can't see the belt itself being the problem, unless it's slipping on the left, and again, that should not happen if the belt routing is correct.
Pete
/ 42" deck - left blade not cutting #5
I have this problem sometimes, throw a level across the pullys sometimes you hit something and knock it off level, or check where the bolts are going through they might be rusted out. I just bought a new 42c deck my other one was finally dead.
Oh Check and see if the back hangers are cracked and pulling away from the deck thats something that also happened to mine.
/ 42" deck - left blade not cutting #6
pulley loose on quill? Those pulleys were bad to "spin out" the center
Pete
I got both from Deere dealer at different times. I bought this mower new @ Home Depot 10+ years ago. I've replced the quill assemblies a few times - the newer ones come with grease fitting.
Will check each of these - thanks for the suggestions!
without engine running, I can engage the blades belt and turn both blades by reaching under the deck, grabbing one blade and pulling on it, so I think the pulleys are still firmly attached to the shaft. BUT, will take another look as I haven't tried to fix this problem in over a year.
I'm now recalling talking to a Deere parts counter guy years ago when I replaced the 1st quill assy and him telling me that a bad quill assembly will cause 1 blade to spin slower. I replaced that quill assy becasue it was worn out and the bearings shot and just happened to ask him about the uneven cut. I'm now wondering if the quill assembly could be bad even though I keep it full of grease. ...... but wouldn't that wear the belt out or cause it to smoke? Just doesn't make sense that the only symptom of a bad quill assy is the blade not cutting well .........
Really appreciate everyone chiming and helping the newbie out!
-steve
/ 42" deck - left blade not cutting #8
I'd start by taking the blades off and checking that the positioner, be it a pin, or something else is properly engaging the blade.
I've had situations where the quill spins the blade "ok" at slow speeds but when hgh speed torque is applied the blade slips and will only spin at about 1/4 speed.
/ 42" deck - left blade not cutting #9
Check the spring that puts tension on the deck belt and see how tight it is. I bet that is your problem.
I experienced a similar problem on my GT275 (3 blade 48" deck) last year after about 14 years/~1400 hours. I wish I had a picture to clarify what I'm talking about, but I'll try my best to explain. There would be a burning smell (burning belt) when I was mowing thick grass; it eventually got worse and the right blade wasn't cutting the grass when under load/torque.
I picked up a new deck belt at the dealer, assuming the current belt was just stretched after a couple seasons of use. After replacing the belt, I still had the same problem.
In the process of removing the deck, I noticed the deck belt tensioner spring had almost no tension in it. I remember several years prior, it had been a lot tighter and harder to pull to release. It had no visual signs of wear/stretch, so I didn't want to replace it. However, I needed to find a way to get it pulled tighter.
I'm not sure about the 42" deck, but on the 48" deck there is a metal hook that is welded to the deck where one end of the spring anchors to. There was a small ~1/4" square hole in the deck roughly 1 inch away from the hook. I used a small nut/bolt/washer I had laying around to act as a new anchor for the spring. With the spring having an extra 1-1.5" of stretch, the tension was a lot better and the blades have been working fine ever since.
/ 42" deck - left blade not cutting #10
I think home deploy starting selling these mowers around 2004-2005, just an FYI, I just replaced a spindle/quill assembly on one that was new from a home depot right when they starting selling them. The left spindle was completely out and the right was prettty tight but turned really hard
/ 42" deck - left blade not cutting #11
As far as spindles, dont cheap out and get the cast aluminum ones they do not last long, the spindle assembly is one place to go with a oem part. I have two of the aluminum ones that cracked at the bolt holes (from hitting a rock).
/ 42" deck - left blade not cutting #13
Sorry on my mower deck the ones that work best are the first link,
John Deere Mower Deck Spindles 3 Of AM124512 46" STX46 | eBay
are the good ones, I dont think these are cast aluminum,
the cast ones that I have had look like this, and they failed but they are oem, (but they are not the oem for the 42c).
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
I just remembered one more thing that may cause uneaven cutting, tire pressure if one is off it will give you some strange cutts too.
again, I much appreciate all the suggestions.
We bought the mower April 2002 (just found the folder with the paperwork).
The quill assemblies I have replaced over the years have all come from Deere. I admit that I had sticker shock at the price of a new belt from Deere, so got a cheaper one off ebay.
Have not thought about the tension on the belt when engaged - will look at that. One thing I did do last fall was unhook the belt and gave each blade a good spin by hand to see if the left one would stop quicker than the right, indicating it had more internal drag. Both would continue to spin about same, so figured the quill assy was not the problem this time.
/ 42" deck - left blade not cutting #15
When you check your blades you do clean the old grass out of the deck right? I am assuming you do, just a question
ahhhh, well, hmmmmmmm ....... can't remember last time I actually cleaned the old grass from the underside of the deck. :eek:
/ 42" deck - left blade not cutting #17
Well if you don't clean the grass out it can actually build up enough that is wears the blades out and the air flow can't create a vacuum to move the old grass out. Everyone should clean their the bottom side out atleast once a year and more if you mulch or now a lot of wet grass.
2005 John Deere 7420 (A60462)
2005 John Deere...
JOHN DEERE 544K LOADER (A63569)
JOHN DEERE 544K...
2006 Polaris Sportsman 90 (A64047)
2006 Polaris...
2019 Maxx-D 40' Gooseneck Trailer w/ Mega Ramps (A64047)
2019 Maxx-D 40'...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63118)
PENDING SELLER...
2014 STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
2014 STARCRAFT...
