Thread posting "Submit" seems to hang
/ Thread posting "Submit" seems to hang #22
Notice the double post.
I've started to notice a lot of double posts lately, probably because people get sick of waiting on their post to submit and click the submit button again, resulting in a double post.
This submit problem is actually starting to get very annoying.
/ Thread posting "Submit" seems to hang #23
On my phone it indicates that the posting failed although it never does as indicated by the fast post times people are posting. I just click the 'Cancel' after a couple of seconds and the posting, without fail, is successfully posted. This happens about every other post I make.
/ Thread posting "Submit" seems to hang #24
I think the problem isn't actually with the posting portion of the process because posts seem to go through, even if I get tired of waiting and simply close the page. Personally, I believe that something is happening during the redirect portion of the process, which returns you to the page after the post has been made. Either way, it's a PITA.
/ Thread posting "Submit" seems to hang #25
My responses in threads are double posting as well, even though I'm only hitting "submit" once. It takes a while to respond and I get a message saying something to the effect "This is a duplicate post in a thread you previously responded to"
/ Thread posting "Submit" seems to hang #26
I just had one that hung for a lonnngggg time...
Here is the tech data:
Page generated in 0.06685 seconds with 16 queries
/ Thread posting "Submit" seems to hang #29
I thought it was my VZ aircard just being slow, glad it's not just me.
Also when I'm on my Ipad, it gets hung up everytime, I cancel out and it stills appears.
/ Thread posting "Submit" seems to hang #30
Edit: this post took ~20 seconds to go through on my end. But as soon as I clicked submit, I opened a new tab of TBN and my post showed up in the new tab, while the tab for this post was still in the "stall" mode. Hope we can figure this out
I have seen this same behavior on many threads over the last few days.
Running Firefox 11 Beta at home and 10 at work on a Windows 7 x64 PC.
Edit: This post went in instantly
Aaron Z
/ Thread posting "Submit" seems to hang #32
That interesting, I haven't had any posts take longer than a few seconds to go through. However 75% of them end up a double-post. One click, two posts. Chrome browser on an updated mac book pro.
Edit: Of course, now I get one! Warning message about the duplicate, then no such duplicate exists.
/ Thread posting "Submit" seems to hang #34
There's your problem. :confised2:
Negative, ghost rider. I use PCs all day at work. Very nice to get home and back on the trouble-free mac.
/ Thread posting "Submit" seems to hang #35
I figured out how to beat it, click submit , then click it again and when it says you just made a duplicate post click on the link in that notification and it stops the madness.
/ Thread posting "Submit" seems to hang #36
Had one that took ~20 seconds to go through.
Thread: Hydraulic mystery - TractorByNet.com
Compose page load time: Page generated in 0.04205 seconds with 16 queries
Load time after the comment was posted: Page generated in 0.05166 seconds with 15 queries
Was the first reply to the thread.
Edit: This reply went in quickly. Says that Page generated in 0.17695 seconds with 15 queries
Aaron Z
/ Thread posting "Submit" seems to hang #39
Also, attaching files seems to be having issues. I tried uploading a 13.6 KB PNG and it sat there saying "waiting on server tractorbynet.com" for ~2 minutes (causing other TBN windows to freeze and not load) until I closed the window and found that the picture had already loaded.
5 minutes later, I was experimenting and an 81.9KB file (http://www.tractorbynet.com/forums/attachment.php?attachmentid=256374&stc=1&d=1331959026) uploaded instantly, but hung when I tried to delete it.
That was in 4x6 I beam, what will it hold? - Page 2 - TractorByNet.com and after posting, the page said "Page generated in 0.08615 seconds with 22 queries"
Aaron Z
/ Thread posting "Submit" seems to hang #40
Just posted in a thread called ''My New Firewood Toys''.
It took a while to go through.
Page generated in 0.04479 seconds with 20 queries
Bill
UNUSED IRANCH IRTPL TWO-POST LIFT (A65055)
UNUSED IRANCH...
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64278)
2023 JOHN DEERE...
(2 1/2) SPOOLS OF (500) FT OF 10/3 WOG PUMP CABLE (A65055)
(2 1/2) SPOOLS OF...
2003 NISSAN 350Z (A67148)
2003 NISSAN 350Z...
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
