Let's see your welds...
/ Let's see your welds... #101
Perhaps I could get a critique?
Well I'm no pro, but I'd say you need to turn the amps and volts up. And slow your travel speed down to get more fill. Good rule of thumb, anything that produces slag, you should drag, which forces the slag to trail behind the puddle. To help with filling the craters, tighten up the stickout, and move backwards for say 3/8 to 1/2 inch, and pause for a second or two.
/ Let's see your welds... #102
Well I went out and bought a Lincoln pro 140 MIG welder last week. Today I tried it out by welding a couple of links on the top of my bucket. This was the first time I ever used a MIG welder and I think it worked ok. I watched several videos on utube, read the book a couple times and followed the settings in the chart on the machine. Its been 40 years since I last welded anything and that was with a Montgomery Ward 220 volt stick machine and I never quite got the hang of it. I used the .030 flux core wire that came with it and set it at range D, speed 4.5. I have no idea what that equates to in amps or speed but it seemed to work. Here are pictures of how it came out. Perhaps I could get a critique? I'm sure I need more practice - its hard to move slow and even.
P.S. My wife came out to look at what I was doing and asked if those were handles for riding in the bucket?
John C.
Those welds look pretty good and I think they will hold up to whatever your loader can dish out.
BUT...I dont think the links are up to it. You should have welded on some actual "weldable chain hooks" on there instead. I think you will have them bent and twisted in no time to the point they wont open and close. And with that style, if they dont close, they arent that strong and will bend even worse. But this is just my :2cents: and its worth what you paid for it:D
/ Let's see your welds... #103
LD1
Well you are probably right about the weldable chain links but I had these laying around in the garage already. Actually I don't care if they ever open, they are big enough (1/2 inch diameter) that the hooks on my chains clip right on and if I needed to I could even run the smaller chain through them. I thought about welding them shut but didn't. Now that I have a welder, I am looking around for things to weld. :D They are strong, they are stamped with a working load limit of 3300 pounds each and I will never lift anything near that heavy.
Got another question though - the welder also came with a roll of steel wire that doesn't have flux in it. I assume that I need to use gas with this and that it will not work otherwise. I have about 1/3 tank of helium left over from filling balloons a year ago. Will this work or do I need to get CO2 or some other mix of gas?? Is there any real advantage of using the gas vs the flux core wire?
John C.
/ Let's see your welds... #104
ShieldArc.
Thanks, I have only one higher heat setting on this thing, I will try it out when I get something to weld. I am going to have to take the trash to the dump this weekend and will have to scrounge around for some scrap metal to practice on. I am sure I need lots of practice but I am already better with this thing than I ever was with my old stick welder. I suspect that this was at the top end of what could be welded with this light welder and that it is more appropriate for lighter weight stuff. The chart with it tops out at 1/4 inch thickness.
John C.
/ Let's see your welds... #105
This is far from a perfect weld, but good enough for the average home owner. .045 Lincoln NR-212 on 1/4 inch flatbar. Notice how the crater is fuller than the ones in your pictures? Soon as I want to start thinking about stopping, I turn the gun to more of a straight in angle, tighten up the stickout, (this will cool things down), and go backwards 3/8 to 1/2 inch, and pause for a second or two.
/ Let's see your welds... #106
Shield Arc,
Wow that is a lot better weld. Just one question, what do you mean by tighten up on the stick out? I understood the rest of it but am having a
little bit of problem with the terminology.
Thanks,
John C.
/ Let's see your welds... #107
The length of wire from the contact tip to the metal is called stickout. With Mig and most fluxcore self shielded wires I'll run 3/8 to 1/2 inch stickout. NR-232, and NR-233, and Coreshield 8, along with fluxcore gas shielded wires I'll run 3/4 inch stickout. If you lengthen the stickout you increase the voltage, (to a point) if you shorten the stickout you drop the voltage, (which cools the puddle).
/ Let's see your welds... #108
John C.
You have to use Argon/CO2 mix. Most common is 75% Argon/25% CO2.
The advantages is that it is a cleaner/ less messy/ less spattery weld. (I've been told). But I have honestly never ran flux-core. We have always used gas.
/ Let's see your welds... #110
Thanks for the explanation.
Next week when I get some time I am going
to try these things and pay attention to
exactly what I am doing. I believe I was using
about 1/2 inch of stick out give or take a little but only
because it seemed to feel right - not for any logical
reason.
I really appreciate the advice. IT has been helpful
John C.
/ Let's see your welds... #111
I'm going to ask the dumb questions here to see if I'm at least close to being on the right track...
If you increase the stickout, the resistance of the wire increases, and if the current is constant then the voltage increases (not infinitely but somewhat). Does this increase the weld penetration? I have noticed that changing the angle of the gun increases/decreases penetration to some extent but I've never tried increasing the stickout. I always thought the "right thing" to do was to keep the wire as short as possible without touching the gun tip to the weld. Don't ask me where I got that from but evidently it's not always the thing to do!
/ Let's see your welds... #112
I really wouldn't say it helps with penetration, but the puddle will become hotter / more liquid! If you lengthen the stickout too far, you can loose all heat / power, and stick the wire.
The stickout can vary with some wires, you just have to adjust the voltage. Now some of the T-8 wires the proper stickout is critical! T-8 wires are required to meet FEMA 353, and other seismic codes.
/ Let's see your welds... #113
A couple key points that the newbies won't necessarily get from the description SA posted:
1. Stickout length is from the CONTACT tip, no the edge of the shielding cup.
2. More important than anything is consistency. You need to hold the distance to the joint (and thus the stickout) constant through the weld or things will vary and you will see it. Whether it is significant or not depends on what you are doing and how bad it varies.
These are the sort of things that most experienced welders get, but isn't always obvious to the new folks.
And really, SA, stop saying you aren't a pro. If you want to say retired welder, fine, but lets be real here...you ain't foolin' nobody! :laughing:
/ Let's see your welds... #114
As a disclaimer until recently I only O/A welded which I learned 40+ years ago from my father. I recently got a stick welder that I am trying my hand at. One of our members has made me an offer that I need to take advantage of but here are a couple of pictures and questions.
The plate is 1/8 inch mild steel.
First picture is of 6011 rod The top and bottom two lines are reverse polarity the two middle are straight polarity. All are at 60 amps. I had a liitle too much penetration on the bottom one as I had distortion on the back side. Lines were done from top to bottom in order. I believe I was moving too fast on the first two and my steadiness is pathetic. I seem to have more splatter than I thought I would get.
Comments?
The second picture is of 7018 rod. The top and bottom two lines are reverse polarity the two middle are straight polarity. All are at 90 amps as I had a problem keeping the arc going at 60-85 amps.. ?? I was very surprised at the slag that 7018 flux leaves behind compared to the 6011 which is practically nothing. What caused the pores in the welds and what was I doing wrong? Again I think I was moving too fast in general.
Comments?
/ Let's see your welds... #115
I take it has you're left handed?
Generally both 6011, and 7018 run on reverse polarity. I will run 7018 on straight polarity for open root welding only. Your 6011 welds don't look all that bad! Looks like you were dragging the rod more so than using a whipping, (back and forth) motion. The splatter could be a little too much arc length, or maybe just the brand of rod. The 7018 weld with pin holes, the width of the weld leads me to believe the arc length was too much. With all your 7018 welds looks like your biggest problem is travel speed. Slow down some!
Honestly, its hard for anybody to make welds look good on a flat plate! Very easy to make a weld look good on a fillet "T". Also easy to make a weld look good if you take your grinder and grind a groove in a flat plate, and fill the groove with weld. Try it, you'll be surprised!;)
/ Let's see your welds... #116
No, right handed. Then I looked at the pictures I took. I took them upside down from the position I welded the lines in thus it looks like I am left handed (no just upside down):laughing:
When I get back tommorrow I will try slowing down as I surmised in my post and as you stated. I'll either do "T" fillet or grind a "V" in the plate and see how it comes out. I was wondering if I was letting the arc get a bit long so will try to keep it a bit closer as well. Thanks for the suggestions.
/ Let's see your welds... #117
If you have any soap stone run a sraight line with it so you have a gauge to follow. But learning how to run perfectly straight with no aid is the way to train your eyes. With this trade you gotta force yourself to turn your brain into a temporarry computer. It will help in the long run, trust me! Focus, focus, focus.
/ Let's see your welds... #118
Bored to death this morning, so decided to build a roll cage for the new millermatic 211. Kept me busy for a while, now bored waitin for paint to dry! BEER BREAK!!!!!
/ Let's see your welds... #119
Paint dry finally! Just figd I would send some pictures. Quiet day here guys. Figd while the new machine was still new I would do something to help her future before I start abusing her.
Can anyone comment on a comparison between the Millermatic 211 and Lincoln 216? I've been thinking of a Lincoln but lots of guys like the Miller and I just don't know enough about them.
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
UNUSED SWICT 84" BUCKET (A64280)
UNUSED SWICT 84"...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2022 TrailMaster Gas Cart (A61574)
2022 TrailMaster...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
