LA302 BUCKET LEVEL INDICATOR
/ LA302 BUCKET LEVEL INDICATOR #1
600rider
Gold Member
union city pa
2004 kubota b7510
Hey Kubota, whats with the crappy level indicators on your smaller FEL's?
Week 3 of projects for me....since there is no snow to ride the sled on, I decided to get another project done.
Do you have the crappy level indicator that Kubota puts on the smaller loaders? I laughed when I saw it and asked the dealer if there was an option for the rod type indicator, Nope was the answer so I have been looking at different types and Used a modified version I saw on a Mahrinda.
I started by making new pins for the curl cylinder to make them 1" longer then drilled the center and tapped it with 5/16x24x 5/8 deep. Made an "L" bracket out of .090 material at work with a 5/16 hole on one side and 3/4 hole on the other side. Then made a rod 7/16 dia. 28 1/2" long and welded a small lug on the end with a 5/16" hole and bolted it to the lower curl pin. Then I bolted the "L" bracket to the upper curl pin. Next I cut a piece of 1/2" i.d. tube 22" long slid the tube over the rod and into the "L" bracket, with the bucket level I matched the end of the tube to the end of the rod and welded it there. DONE! About 3 hrs. and I now have a level indicator that is usable!! Simple as that Kubota!!! Total cost is about $5.00!
When the rod is flush with the end of the tube the bucket is level!
I will get some paint on it as soon as it warms up enough.
/ LA302 BUCKET LEVEL INDICATOR #2
Nice job 600rider I have a B3000 HST andasked Kubota the same question
and got the same answer. I think i'll try your answer to the fix.:thumbsup:
Thanks rickshaw, It really was that simple to make!
I took it off today and painted it. Hows it look now?
/ LA302 BUCKET LEVEL INDICATOR #4
Looks great ! sometimes it's the simple things that make us happy .:)
/ LA302 BUCKET LEVEL INDICATOR #5
Pretty slick 600rider......You could make-em and sell-um.......
TBN needs more advertisers........:thumbsup:
Thanks Guys, I thought about making them and selling them.......for just a second! :laughing: I will be making one for my buddy that let me copy his quick hitch though! :thumbsup:
Here's a couple more pics of it. I also shot the ends of the pins that will be sticking out.
/ LA302 BUCKET LEVEL INDICATOR #8
Very nice job! I like how you mounted the tube to the upper pin. My JD uses brackets and hose clamps to the curl/dump cylinder. You way is much cleaner looking. Have you tried it out? any binding issues?
To save the cost of new pins, you could weld the head of a bolt to the oringinal pin. Use a spacer on the lower pin and make the "L" longer bracket to suit at the upper pin.
I would use 3/8 or 1/2 diameter bolts, length to suit and locking nuts.
Thanks Zebrafive, I have tried it out and it works perfectly! I drilled the holes shallow and bottomed out the bolts to lock them and left enough room so they didn't bind the indicator. My pins are just 3/4" so I figured 5/16 bolts would be fine. I didn't want to weld the bolt heads to the pins because I wanted to protect the threads for easy removal if needed. I had some 3/4" round bar on the shelf to make the longer pins so cost was minimal
/ LA302 BUCKET LEVEL INDICATOR #10
I have always wondered why a pendulum type level indicator is not used. It would have the advantage of showing a level bucket / forks no matter what elevation the FEL is at.
The "no moving parts" level indicator (sticker :laughing: ) on my Kubota bucket is worthless because the previous owner used it to hook a chain and it is bent up into a hump. I've been thinking of hammering it back flat then using it for a base for an angle with a pin and a suspended rod. Am I missing something?
/ LA302 BUCKET LEVEL INDICATOR #11
Nice job, now is there a way to kick out the return automaticly when level? I know I'm asking a bunch, and your's is top of the line for people like me, but continue working on it for the return auto level and kick out with the return lever. Has to be simple without any hyd. changes. Cat used one years ago that pushed a simple pump (manual) that would push the lever into the neutral position when then bucket was level or you could overide with more pressure on the lever.
Three (3) John Deere 6000-Series Hood Guards (A63116)
Three (3) John...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
POLARIS RANGER 1000 RTV (A62130)
POLARIS RANGER...
(4)-8 LUG FORD WHEELS (A62131)
(4)-8 LUG FORD...
