White Oak - Mission Style Sofa Table
/ White Oak - Mission Style Sofa Table #1
scott_vt
Super Member
east wells,vt
1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Good Afternoon Guys,
My youngest son asked me to build him a sofa table for his newly remodeled home. He moved in there this past fall, and its slowly comming together for him...
I thought I would share the project on TBN, and how I go about building something like this.
White oak is one of my favorites, and I pretty much use it exclusively when ever Im doing a mission style piece.
Im presently about half way done building this table, but I will try to cover everything from start to finish.
I had a fairly good plan in my head to start with, so I started jotting down some sizes, and went from there. The table will be situated behind his family room sofa, with the intension that his buddies can sit at this sofa table on stools, while others are sitting on the sofa, and all can watch the all important sunday football games, while partaking in their favorite beverage ! :)
The table will be counter height, 36", and be able to accomadate three large beer swilling buddies...
So here are my dimensions, the table top will be 7/8"thk by18" wide and 68" long.There will be no lower rail on the front side of the table, so that three stools can be stored underneath, while not being used.
Knowing my rough dimensions, its time to go to my local saw mill to get things rolling. I like to purchase my lumber and then leave it in my shop a couple of weeks before I even start milling things up so it can acclomate to its new enviroment.
The trip to the saw mill is allways fun, but you have to have plenty of time to properly select your lumber, I never go when time is an issue...
Here is a picture of what the rough lumber looks like before I start milling it up. The board on the left is 8/4 stock for the legs, and the other board is 5/4 stock used for the top...
BTW, this will probablly will be the last project done before moving my shop to the barn I built on my Vt property...:)
/ White Oak - Mission Style Sofa Table #2
Your project, being that it is made of white oak, will last for generations upon generations. You Son will most definitely appreciate a piece of furniture that is constructed far better than he could buy in the average furniture outlet.:thumbsup:
Good Afternoon Creekbend,
I certainly hope so, with all the junk they sell in some of these supposed furniture outlets, its hard to find good quality ! ;)
I have seen so much laminated chip board junk that stores are charging top dollar for it makes one sick ! :(
Anyway getting back to the table. I started rough cutting the stock for the legs. The finished dimensions will be 1 3/4" sq by 35 1/4" long. I rough cut the legs, 2" sq by 38" long to start and then get one side flat on the joiner, then I plane the thickness to 1 3/4" thk taking equal amounts of stock from each side of the leg. I then go back to the joiner and square the rough side to the previously finished side. And repeat the process over again to get my 1 3/4" sq.
I leave the legs a little long in case I get some checking on the ends, small cracks from the drying process. After getting the legs to the proper length, I made a taper jig, so that I can put a short ,7deg taper on the bottom inside edges of all four legs, 6" long.
You can see in the picture that I made a jig for the table saw so that I can start squaring up the leg stock.
OK a little fast forward to the finished leg..... :)
I think I gave everyone an idea how I went about cutting and milling the table leg. The next job on the legs was to cut the mortises, remember on the first post that I mentioned,there wont be a rail on the bottom front of the table, so I layed out where all the mortises were going with pencil, so as not to put one in the wrong location ! :confused:
I used to cut all my mortises with a jig and plunge router for years but I finally broke down and bought a bench top Delta mortiser a couple of years back. As long as the mortising chisels are kept good and sharp, this little unit works great.
The rails are going to finish in thickness at 7/8", so I layed out the mortise locations, so that when the rails are assembled to the legs, I will have an 1/8" reveal between the edge of the leg and the rail.
I cant empathize enough on the importance of getting in the mindset of constantly using stops when trying to make duplicate parts. Whether they are table legs, table rails or cutting mortises, no matter what your doing, they all have to be the same length. This will make the project go so much smoother... :)
Heres the only picture I can find of the table legs with the mortises cut allready, sorry.
In this pic I had allready milled up the boards for the table top and glued and clamped it all together.....
These next pictures, show the table ends, you can see the importance in using stops for all of thses parts, because if you didnt, you would not be getting any tight joints after assembly, and you wouldnt have a quality piece of furniture.
Open joints weakens the furniture, and is the earmark of sloppy craftsmanship... IMO ;)
The first pic is the end rails, tenons done,and the four mortises allready cut in the top and bottom for the slats...
Im sure alot of wood workers use different methods when cutting their tenons. I like to use my dado set, I can set the height using a dial indicator and gage block, thats the old toolmaker coming out of me I quess :). But it works quite well and once I get the height set, I can lock the saw, and they all come out the same, I ususally leave them a few thousanths big and then use a rasp to fit each one individually...
Youll notice the alluminum throat plate in the saw, I made that when I was still working in the shop, I can remove that lexan piece for different widths of the dado set...
Here are a couple additional pics of the table ends...
The tenons have not been milled on the slats in this pic yet....
I forgot to mention that the table rails are 2 1/2" wide, so I went with 3/8" by 1 1/2" tenons on the rails, and matching mortises in the legs.
The slats on the table ends are 1/2" by 1", and I decided to go with 1/4" by 1/2" tenons on these pieces.
After all the parts were milled and fitted, I allways dry assemble and clamp it to make sure all the joints are done correctly...
Here is a pic of the dry assembly in process...
Good Evenin Guys,
After fitting both end assemblies together, I pull everything apart, and pre sand all the parts. I dont get too carried away with sanding at this point because the parts will invariably get banged or scraped before the table is assembled as a complete piece.
You will also notice in the second picture, that I cut a 1/4" by 1/4" dado in the top rail. In the third pic is the clamp that will hold the table top in position to the base. The table top will expand and contract with the seasons, and by using this method of attaching the top it can move without effecting the structural integrity of the base...
/ White Oak - Mission Style Sofa Table #10
Thanks for the detail you are putting in the post. I like the mission style furniture. Your attention to detail is great. I look forward to the rest of the tread.
/ White Oak - Mission Style Sofa Table #11
Looking good! I also love white oak, especially quarter sawn which really high lights the figure and rays in the wood. Is your wood quarter sawn or plain sawn?? Also how do you plan to finish it? I know lots of purists in the Stickley style use the fuming technique, but I use an asphaltum based stain that also really shows the figure of the wood.
Another technique that may be useful in the future would have been to make the legs differently. Some of the large square legs in old Arts and Craft furniture showed the quarter-sawn figure on all four sides. That could be done by laminating a thin piece of quarter-sawn on the "ugly" side, or also by using four quarter-sawn boards joined together in a square with a hollow core. This way, you can make a leg fairly large without the fear of splitting like sometimes happens on a large square piece. I make legs like this using a lock miter bit on my router table and that works really well. Just some thoughts for discussion.
Did not mean to go off on a tangent. Your work looks really great and I will follow the progress of your project! Nice work!!!
/ White Oak - Mission Style Sofa Table #13
Hey Scotty!!!!
Looks like a great project. I'm really enjoying your posts and seeing your pics. You're a true craftsman and your attention to detail if first rate!!!!!
Eddie
/ White Oak - Mission Style Sofa Table #14
Very nice project! I recently started doing a little woodworking, so I am a rank amateur compared to you. I have a question about your wood. When you purchase the oak from the mill, is it kiln dried? If not, do you use a moisture meter to determine when it is usable?
My wife is wanting me to make a farm style kitchen table. I think I am going to attempt the project but want to make sure I don't end up with split wood later on. I plan on using red oak. Any hints about using rough sawn lumber would be appreciated.
/ White Oak - Mission Style Sofa Table #16
Scotty,
Can't wait to see the finished product. hopefully I can get my woodworking shop build in a year or two.
I had a thread of a farmhouse table I recently made for my wife with mostly hand tools. Woodworking equipment is still in storage. You shop has me wishing I could get mine started.
/ White Oak - Mission Style Sofa Table #17
Scotty,
Hunterridge; if you get a chance, how about sending a pic of your table. Maybe send it to me in a private message. I don't want to hijack this thread in any way. Scotty has a very nice project going, and I want to see it to the end.
Good Evenin HCJTractor,
You are on the money on both points !
Gustav Stickley abd his brother are the ones responsible for starting this style of furniture, and your other point of fuming the white oak with ammonia is also right...
I do not have quarter sawn wood for this project, the mill doesnt carry it that often because its more work and the demand is not as high as flat sawn lumber.
The legs do have some nioce ray pattern on them but nothing exceptional. And Im not planning on fuming the table because I have a stain that is fairly cloae to my sons hard wood floor.
TN Hobbyfarmer, thankyou, yes this lumber is kiln dried and as I mentioned earlier I let it sit in my shop for a couiple of weeks before I start milling it up. If I can help you in any way, please feel free and ask, I will certainly try and help.
The next thing I will be doing is making some slats for the long rails, rear of the table.
My son will have thsi table behind his sofa, so unfortunately only the right side of the table and the top will really get seen .:( But some day it may be some where else that its easier to look at... ! :)
Im hoping to do some more work on it later thus week...
Thanks to all for the compliments, its not a terrifically difficult project, actually pretty straight foward, no difficult radiuses or curves to deal with but fun just the same, thanks again !
/ White Oak - Mission Style Sofa Table #19
Scotty,
Only one side might be seen now, but the table will be around for a very long time. Who knows where it will be shown. In any case, it looks to be a proper job. Thanks for posting the photos and the play-by-play. I look forward to the rest.
Cliff
Cliff, good to hear you on along with some of my other TBN friends !
I had a chance to get some more work done on the table. I layed out the long rails between the table ends and cut all the mortices. I believe on a previous post I wrongly mentioned that the slat tenons were 1/4", sorry that is incorrect, they are 3/8" along with all the other mortices in this project ! They are 3/8" by 3/4", and all the slats are 5/8" by 1", which makes forming the tenons quite easy because all the relief cuts are 1/8".
I milled up the stock for the slats and mistakenly grabbed a piece of oak that didnt have the same coloring as all the other slats... So I had to do that whole operation over again, kind of a pain but the coloring difference would have really stood out like a sore thumb.....
I dont think I mentioned it earlier, but when I glued up the ends, I try to be very careful on the amount that I use. Excessive squeez out on the joints is a real pain to clean up, and really isnt necessary for a strong joint. If I do get a small amount, I use a dampened rag, and after the joint has a few minutes of setup time, I will use a single edged razor for final cleanup.
If your not carefull when doing this, when you attempt to stain your piece, the stain wont penetrate that area, making for a sloppy job...
I fitted all the slats in between the long rails, and then checked to see if the ends would fit properly. All table surfaces will get dampened lightly with a sponge to raise the grain, and then sanded once again. And then everything will be finished sanded. Im not quite to that point yet...
Here are a few pics to bring you up to date...
I decided to use three equally spaced slat formations on the back rail, rather than slats all the way across. If you recall, there will be three matching stools, so something to break up the monotony of nothing but slats...
BTW I forgot to mention that since the 1" side of all the slats are cut from flat sawn stock they reveal some very nive ray pattern, the photos dont pick it up but Im sure when the piece is stained it will standout...
