Home Made Cab
/ Home Made Cab #1
Lazye
Kubota b7610
I have a Kubota B7610 with a front mounted snowblower. I got tired of getting covered with snow as the wind swirled around the trees. This motivated me to build my own cab.
It is built out of 1" square steel tubing and 1.5" angle iron. The roof is 16 gauge sheet metal. The windows are going to be 1/8" lexan.
I welded the 1" tubing together for the frame and attached the roof(1.5" angle iron with the sheet metal welded to it) to the frame with bolts.
The whole cab assembly is attached to the tractor with bolts for easier removal during the summer. I have a door attached to the left side of the tractor. Door is constructed from 1" tubing as well. I just used two normal door hinges to attach it.
/ Home Made Cab
Here are the pictures
/ Home Made Cab #3
Looks like your doing a fine job.:thumbsup: Make sure to keep us posted on progress
/ Home Made Cab
I will indeed. I get home tonight and tomorrow I pick up the lexan so hopefully will have another update in a day or two.
/ Home Made Cab #5
What's all that white stuff on the ground behind you? I seem to remember once having something like that around here but it's been so long...
/ Home Made Cab #6
Very nice job. I made a cab several years ago for a Ford 1310 then retrofitted it to fit my B7510. Probably should have started over but after a while I got it to work. It had just a left door on the Ford but added a right door for the "bota because I always thought I wanted a door on that side and I am glad I did.the first cab was 3/4 tube and Aluminum skin with windows from the junk yard. The reinvention was same tube and windows but skinned it with dark Plexi glass. Mine is removable in five pieces and two doors.
Keep up the good work can't wait to see the finished product.
/ Home Made Cab #8
nice looking cab, not much clearance from the rafters, keep up the good work!
/ Home Made Cab
The last few days I have been working at putting the lexan windows on my new cab. I got some lights for free from my father, but they didn't work very good so I bought a couple cheap floodlights from princess auto. I'll test them out tonight.
I bought some rubber matting today and made a panel to attach to the back of my cab and under the toolbox too seal up under the seat.
I got a heater with a fan on it for free and have to figure out how to mount that.
I still have to paint my cab but that will have to wait until it gets much warmer out.
/ Home Made Cab
All that white stuff is what we in the colder climates call snow. It falls from the sky at the most inconvenient times(like when you need to be somewhere but have to plow the snow so you can get out of your driveway).:confused2::mad:
/ Home Made Cab
Do you have pictures of your cab posted somewhere on here?
/ Home Made Cab
Here are my latest pictures. I still have to paint the cab but it works fine for now. I also have to install the heater when I can find the fittings I need.
/ Home Made Cab #13
Very nice! You are very talented!
/ Home Made Cab
Thanks shortthrow50.
It took about 60 hours of my time and cost me approximately $700.00 in materials. 220 for the steel, 400 for the lexan and about 80 for the fasteners, weather stripping and matting.
/ Home Made Cab #15
Very nice! I'm going to build one similar to yours when it warms up. Just the basic framework, plexi and probably a glass windshield. Nice to see how good it can look!!
/ Home Made Cab #16
I agree it looks like nice work.
There is one thing that you need that is missing. You will find that out the first time you use it - a windshield wiper. It is indespensible as you will soon see. Even on a calm day the snow blows up, hits the warm windshield, and melts. You have a choice. You can a distorted view of what is ahead of you, or you will be hopping out periodically to clean it off. It isn't too bad if you are plowing on a calm day, but with a blower it is essential.
Get the wiper. You can see my front one in the picture below. I also have a rear one that I seldom, if ever use.
Kubota B3030 HSDC snowblowing Jan 2012 (HD) - YouTube
/ Home Made Cab
I will put a wiper on it as well. I think once the cab is heated it will melt the snow on the windshield causing visibility issues
/ Home Made Cab #18
Hey don't you know we NEED to see pictures??? Lots of pictures!!! I think that's in the forum bi-laws or something!!
:laughing:
UNUSED RAYTREE RABC44 - 44" ARTICULATING CUTTER (A62131)
UNUSED RAYTREE...
Kubota RTV 500R-A (A64047)
Kubota RTV 500R-A...
John Deere 5090GN (A60462)
John Deere 5090GN...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A62131)
UNUSED WOLVERINE...
2001 Ford Explorer Sport SUV (A61569)
2001 Ford Explorer...
