Drag Harrow Project
/ Drag Harrow Project
My concern is that the hitch arms will too low unless those existing flatbars are angled up some. Then install the top link mast plumb in this position.
I was looking at that too, wished i had the tractor here to test fit. I know my hitch arms will go almost to ground level when lowered all the way. I think I may have to modify the top link connection, my top link may extend that far, not sure. May have to build the 3 point connection completely, I had this old one laying around, came with some other 3 point equipment I had bought about a year ago.
/ Drag Harrow Project #22
keep the pics coming!
/ Drag Harrow Project #23
I bet you're going to have to weld it rigid. Don't let me sound "down" because that really is a nice build.
I may have to, I am curious to see how it does when I get it hooked up. I wish the tractor was not 100 miles away right now, anxious to see what it does. I dont think you sound "down", I like tinkering with projects like this. Sometimes ideas work, sometimes they don't:D
/ Drag Harrow Project #25
I built one a couple years ago--since sold--but I might still have a photo.
/ Drag Harrow Project #26
Here's the one I built. Originally, my intent was to mimic stuff I had seen on the net. It hinged high up so I could fold it for transport. Problem is, it pitched down in front during use and caused the back to kick up. I solved it by making a riged, yet adjustable stiff rod out of "ratchet adjuster" used to replace hyd cylinders for transport. I also had a hyd cylinder so it would fold up for transport. The safety chains held it during transport.
Very nice build! Looks very heavy duty. Do you have pics of how you mounted the ratchet adjuster?
/ Drag Harrow Project #28
Well, I don't. I bought one at TSC--maybe mail order --cut it in half and welded pipe in middle. It was maybe 50 inches long. My harrow was strong enough in the middle to not flex in use but yours looks lighter. A better way for you would be to make the pivot thing rigid and weld two pieces of pipe --one to each rear corner from the "A" frame of the toplink. These would need to be adjustable so you could make one or the other longer or shorter. If you use a LH and RH thread with locknuts you would not have to remove to adjust. This is a tricky thing to engineer.
I'm now rebuilding a drag harrow "harragator" and I have a thread on it in attachments.
http://www.tractorbynet.com/forums/...building-harragator-spike-harrow-project.html
Both concepts are fun and both work. The fun is in the building and welding and doing it by yourself or with kids. They'll never forget it. In fact, I mostly do this stuff because elders helped me 55 years ago. Guess it stuck.
Mine is lighter than yours by far. We're mainly in a sandy loam soil, especially across a creek where I will be using it alot...its like beach sandy on that side. So I was trying to stay light so as to not dig in too deep, yet strong enough, not sure I achieved that...still not out much $$ so far, but we are having fun. Gotcha on the ratchet design, I have access to some big turnbuckles I can modify, think they 1-1/4" or 1-1/2", were used for guy wires on a work over rig at one time.They about 3' long closed position and have the jam nuts on them already. I found out today my shoulder surgery got bumped up to next Monday:thumbsup:, so definently going to property to see what it does this weekend, plus got to get the back yard cleanup and make my wife happy since she will be baby sitting me for a few days next week:laughing:
Thanks for the advice and ideas.
/ Drag Harrow Project #30
When I first built my harrow with the pivot points across from the hitchpins I found that I was pulling the harrow with a rolling motion due to the high hitch point. I think if the hitch has longer vertical pieces that extend down close to the ground it should pull much better. Too much hitch weight might cause it to flip up in the rear also.
Sixdogs, lookiing at your harrow, looks heavy duty and a nice build. Curious what is all that metal for up top by the hitch. Looks like it weighs enough to make the front dig in deeper.
I have thought about building a combination tool for seeding (poor mans version) with a drop seeder up front mounted ahead of the harrow and adding rollers at the rear. I could use the roller with hydraulic raise and lower which would transfer some weight to the harrow for the opening and smoothing process roller raised up. Then the second pass dropping seed, harrowing over the seed and roller down to press the dirt down.
What do you guys think?
/ Drag Harrow Project #31
Sixdogs, lookiing at your harrow, looks heavy duty and a nice build. Curious what is all that metal for up top by the hitch. Looks like it weighs enough to make the front dig in deeper....
It's my rotating hitch framework. The hitch is off a MF toolbar.
It couldn't dig in because I didn't drop the unit all the way to the full contact with the ground. The rotating hitch did not work for me.
My father and I have been kicking this idea around, very similar as you describe. Would like to see if anyone tries a build.
/ Drag Harrow Project #33
I am thinking of crusing around a few used equipment yards in west Texas to see what I can find for this. It has been many years since I have done much looking for equipment so I am curious what is out there anyway. Use to have a large place in Plainview TX IIRC, want to check that out.
I am thinking of crusing around a few used equipment yards in west Texas to see what I can find for this. It has been many years since I have done much looking for equipment so I am curious what is out there anyway. Use to have a large place in Plainview TX IIRC, want to checxh that out.
Wished I was closer, would like to see some that stuff out there.Thats prolly a good 600 miles from me. I do have an old planter of some sort, the box is in good shape, part of the drive chain is there, think ground wheel is gone. Has to have been sitting for atleast 30 yrs now. I'll get some pics this weekend and post up to if anyone recognizes it..might be worth trying to save.
The drag works! No kick up, pulls good. I am going to have to modify the top link connection. Had to use a short piece of chain, as my top link is not long enough. Was able lift the drag and lower it. I am going to raise the point where the chain connects to the draw bar. Think i am going to use cable and turnbuckles instead of chain.
/ Drag Harrow Project #36
Excellent. Any photos after completion?
When i get back home Sunday will put a couple pics of how it is on the tractor. Bringing draw bar back home to modify and will have pics as i go on it. Now that I know it works I feel alot better.
Hooked up on the tractor
/ Drag Harrow Project #39
Glad to hear it worked out for you, hope to to see the finished product soon.:thumbsup:
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
2012 International (A59230)
2012 International...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
