Oh boy.. yes 43 amps is a lot of amps. and nothing I have talked about or shown is going to work for that.. let me look around some.. I was half expecting you to come back and say 4 amps.. Man a 1/2 horse motor to sling some salt? whatever the heck for? and this is wired up with #4 wire? from the battery?.. That is a healthy motor. Do your lights go dim when you turn this thing on? so 43 amps X 13.8 volts (nominal charging system voltage with engine reved up) = 593.4 watts. 1/2 horsepower = 746/2= 373watts/593.4 watts = 62.8 % effecient.. yeah, could be about right. WOW is all I can say.
I am wondering if you can do something mechanical to narrow the "spreader beam" instead of slowing down the motor. How about is it direct drive or chain driven.. change sprocket? Lets think out of the box here. Dropping 4 or so volt (just and estimate) at 43 amps is like 172 watts to dissipate as heat.. Now we are talking big multiple pass transistors and really big heat sink to make a linear pass transistor regulator. This is not a very good approach.. A switcher is going to be the way, but you are not liable to find one on flea bay for $20 bucks like I was headed for. that will handle this much current. Maybe someone else has some better ideas. ?
James K0UA
