Tires 6230
/ 6230 #2
What do you mean by no axles. Well obviously no if there is no drive getting to the tires the tires will not spin unless its a magical tire. :D
/ 6230 #3
It's all done with magnets, smoke and mirrors, and pixie dust. :laughing:
Seriously now...to the OP, welcome to TBN, and I assume you're in Greeley, Colorado. If so, contact Colorado Equipment as they are you're local Deere dealer.
/ 6230 #4
Now... if I had to make a "reasonable" guess at what the OP was asking... he's wondering if you can put a larger tire/rim combination on a tractor that has a bolt/hub configuration versus the adjustable axle stub configuration.
Sound reasonable?
Now, I don't know if that particular tire would fit - given the dimensions of the tractors fenders, etc. And I wouldn't venture how that tire size might affect the transmission ratios and the final drive of the tractor.
mjncad is correct... visit with the dealer.
AKfish
/ 6230 #5
Can you put 12.4 42 tires on a 6230 JD without axles?
If you're referring to the type rear axles called "flanged"(similar to photo) that the wheel bolts to with 8 bolts I didn't find a 42" wheel listed in either 6230 parts catalog.
/ 6230 #6
There ya go! "Flanged", huh? (A hub is kinda, sorta similar..) Thanks, Tx Jim.
AKfish
/ 6230 #7
AKfish
That's what the JD rep's called them at the sales meetings I attended when I worked for a dealer.
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
2014 KUBOTA SVL75-2 SKID STEER (INOPERABLE) (A63569)
2014 KUBOTA...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2012 Dodge Grand Caravan VAN (A61574)
2012 Dodge Grand...
