Tires 6230
/ 6230 #2
What do you mean by no axles. Well obviously no if there is no drive getting to the tires the tires will not spin unless its a magical tire. :D
/ 6230 #3
It's all done with magnets, smoke and mirrors, and pixie dust. :laughing:
Seriously now...to the OP, welcome to TBN, and I assume you're in Greeley, Colorado. If so, contact Colorado Equipment as they are you're local Deere dealer.
/ 6230 #4
Now... if I had to make a "reasonable" guess at what the OP was asking... he's wondering if you can put a larger tire/rim combination on a tractor that has a bolt/hub configuration versus the adjustable axle stub configuration.
Sound reasonable?
Now, I don't know if that particular tire would fit - given the dimensions of the tractors fenders, etc. And I wouldn't venture how that tire size might affect the transmission ratios and the final drive of the tractor.
mjncad is correct... visit with the dealer.
AKfish
/ 6230 #5
Can you put 12.4 42 tires on a 6230 JD without axles?
If you're referring to the type rear axles called "flanged"(similar to photo) that the wheel bolts to with 8 bolts I didn't find a 42" wheel listed in either 6230 parts catalog.
/ 6230 #6
There ya go! "Flanged", huh? (A hub is kinda, sorta similar..) Thanks, Tx Jim.
AKfish
/ 6230 #7
AKfish
That's what the JD rep's called them at the sales meetings I attended when I worked for a dealer.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
Quick Hitch Mini Excavator Attachment (A61572)
Quick Hitch Mini...
NO ADDITIONAL ONLINE BUYERS PREMIUM ON BID.FIVESTARAUCTION.COM (A64047)
NO ADDITIONAL...
2016 EZ Trail Seed Tender (A64047)
2016 EZ Trail Seed...
