Tires 6230
/ 6230 #2
What do you mean by no axles. Well obviously no if there is no drive getting to the tires the tires will not spin unless its a magical tire. :D
/ 6230 #3
It's all done with magnets, smoke and mirrors, and pixie dust. :laughing:
Seriously now...to the OP, welcome to TBN, and I assume you're in Greeley, Colorado. If so, contact Colorado Equipment as they are you're local Deere dealer.
/ 6230 #4
Now... if I had to make a "reasonable" guess at what the OP was asking... he's wondering if you can put a larger tire/rim combination on a tractor that has a bolt/hub configuration versus the adjustable axle stub configuration.
Sound reasonable?
Now, I don't know if that particular tire would fit - given the dimensions of the tractors fenders, etc. And I wouldn't venture how that tire size might affect the transmission ratios and the final drive of the tractor.
mjncad is correct... visit with the dealer.
AKfish
/ 6230 #5
Can you put 12.4 42 tires on a 6230 JD without axles?
If you're referring to the type rear axles called "flanged"(similar to photo) that the wheel bolts to with 8 bolts I didn't find a 42" wheel listed in either 6230 parts catalog.
/ 6230 #6
There ya go! "Flanged", huh? (A hub is kinda, sorta similar..) Thanks, Tx Jim.
AKfish
/ 6230 #7
AKfish
That's what the JD rep's called them at the sales meetings I attended when I worked for a dealer.
