New/Old strobe lights
/ New/Old strobe lights
Why didn't you put the molex connectors inside the cab, to protect them from the weather?
EDIT: Nevermind, looks like the wires from the LINZ6's were too short for that.
I did on the B3030 and it was a real pain to remove them. I might as well just used butt connectors. Also the connectors won't go through the little hole and grommet. So I did it this way this time. I'll just have to see if I have any issues. If so, I'll just have to order some Weatherpack connectors.
/ New/Old strobe lights #12
I would just apply some silicone grease to the inside of the molex plugs and assemble. Not like on a snowplow truck where it's exposed to salt spray all the time.
I filled them with dielectric grease and then rubber taped them. That should be plenty.:thumbsup:
/ New/Old strobe lights #14
That was easy. Here's the video.
Safety Lighting on Kubota L5740 - YouTube
My first video, so I have a lot to learn. I'll try to do better next time.
Looks good. The new feature that allows video embedding has really simplified things here.
I like the traffic advisor. Search for Member 4shorts. He does plowing in a Kubota as well. He's got a pretty decent strobe setup too.
Oh yeah! 4shorts is an unofficial mentor of mine and and inspiration.
Great job!!! Love the traffic advisor!!!
Was the install very difficult?
Thank you very much!
I don't think so, but that really is a matter of opinion and relative skills. Making some brackets to hold the lights, running the control wire from the lights to the controller, power and ground, and mounting the controller box. That's pretty much it. It might depend on what your installing it on as well. My L5740 top comes off in a matter of minutes, speeding up the wiring. Kubota supplied a factory auxiliary plug at the base of the left B pillar with a positive and ground, so I didn't even have to run that. So thanks to Kubota the install was pretty easy.:thumbsup::cool2:
2017 Komatsu PC138USLC (A60462)
2017 Komatsu...
2025 SDLanch SDLE20 Diesel Mini Excavator (A60352)
2025 SDLanch...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
CFG QK20R (A60463)
CFG QK20R (A60463)
John Deere 5100M (A53317)
John Deere 5100M...
1007 (A61166)
1007 (A61166)
