John Deere B Grain Drill
/ John Deere B Grain Drill #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
Can a John Deere B Grain Drill seed/drill fescue without having a separate grass seeder box?
/ John Deere B Grain Drill #3
Grass seed is pretty difficult to seed through the fertilizer box since the seed is so tiny. You can try to cover the input to the seed cups with some sort of cover with a hole or slit and see if it works. Of course, the fescue will be dropped in rows along the direction of travel instead of in a solid line side to side unless you rig up some type of seed chute to spread the seed in a line.
I restored an old Minneapolis Moline P3-6 grain drill (10 ft wide, 20 drops, single disc openers) a few years ago. Use it to plant oats.
I used the two JD grass seeder boxes that came with the drill to make a drop seeder that I use to seed the hayfield with cover crop (lana vetch-ryegrass mix).
I welded up a frame to attach to the 3pt hitch on my 2008 Mahindra 5525. Added the grass boxes, drive wheels/chain/axles, and a pair of two-bounce seed chutes to spread the seed uniformly in a lateral line about 10-ft wide.
Good luck
/ John Deere B Grain Drill #4
Flusher, nice job on both. How much did you spend on the drop seeder versus buying a 3 point spreader?
View attachment 249079View attachment 249080View attachment 249081View attachment 249082
View attachment 249083View attachment 249084View attachment 249085
Good luck
How are you getting good ground to seed contact? Are you dragging after spreading the seed?
I always thought there was a seperate box for fertilizer.
My understanding is a drill will have a seed box, a fertilizer box and a seperate grass seed box (and maybe even a 4th box for small seeds ie clover).
/ John Deere B Grain Drill #6
Use a 10 ft wide cultipacker to press the seed into the soil.
My old 10 ft wide Minneapolis Moline P3-6 drill has two large boxes (5 ft wide) for fertilizer, large size seed or a mix of both and two small 5 ft wide grass seed boxes. Modern grain drills come with more boxes and a more advanced design for spreading seed and fertilizer.
/ John Deere B Grain Drill #7
I have about $300 in parts for that drop seeder.
FRONT MOUNT BLADE W/ MOUNTS (A63291)
FRONT MOUNT BLADE...
JOHN DEERE 8360R TRACTOR (A63291)
JOHN DEERE 8360R...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
Decorative Mermaid Light Post (A61574)
Decorative Mermaid...
2018 Volkswagen Passat Sedan (A61574)
2018 Volkswagen...
UNUSED WOLVERINE HYD SNOW PUSHER (A64281)
UNUSED WOLVERINE...
