Land Pride grading scraper
/ Land Pride grading scraper #201
Well, food for thought. Picked up a 5' Chinese AgriEase, the Land Pride twin, for $950 but I'm taking it back. It didn't even make it to the ground. As I prepared to adjust the scraper depth I noticed that the blades were flush to above the 4 or 5" angle iron backers - nearly 3/8" on one side. It'd probably work more or less but just seems like a stupid design. Supposed to pick up a $1200 Rankin (made in and engineered by Americans) Monday or Tuesday.
/ Land Pride grading scraper #202
Joel,
When I was building my landplane utilizing 6" wide double edged blades it was east to see that a minimum of 4" angle is needed to make them work. What was the size of the angle iron on this clone?
What I did to make mine heavier was use 8" wide x 5/8" thick flatbar and two pieces of 3x3x3/8" angle to box it in for extra rigidity. Combined that is alot more material than the 4x4x1/2" angle iron.
/ Land Pride grading scraper #203
Yours is waaaay stronger. This has 4 1/2 x 4 1/2 x 3/16 (not even 1/2"!) angle backing each 5 7/8" x 3/8 blade. As it is the AgriEase backer hits the ground before the blade - not much, but wrong none the less. Can't tell you Rankin's matl thicknesses (I think more but all the 5 ft'er brands claim to weight about the same) but Rankin offsets the blade down on the backer matl so's to get some blade below the backer.
/ Land Pride grading scraper #204
I will have to check mine out this weekend but I suspect my blades are extended about 1/2 to 3/4 inch below the flatbar. The grader blades on mine are 6" wide x 96" length x 5/8" thick doubled edged reversible. These are bolted down the centerline, some of the blades I found had the holes offset which made them worthless for turning over.
These planes are an easy build if you have some welding skills you can buy the materials for less than half the cost of buying one. Mine worked out to about $1 / lb.
/ Land Pride grading scraper #205
That wasn't my experience. I started pricing building my own, & the 4"x4" box to right off the bat was a huge cost. Of course, it's all about the source, & I don't have any special relationship with a steel provider - It was gonna be retail all the way for me.
/ Land Pride grading scraper #206
I was able to cut some corners on price for instance the wide flange beams I used were two 5 1/2' drops in the cut off pile. Most of the bar and angle iron is running about .56/lb in my area. I buy the 4x4 tubing and other sizes in decent quantities as I use this to build gates and wrought iron fencing. The blades were about $220 each so these were easily the most expensive part of the build.
/ Land Pride grading scraper #207
The blades for both are drilled on center but the holes on the Rankin backer matl are offcentered down.
/ Land Pride grading scraper #208
Does anyone have a feel if a Kubota GL3540 would have any issues pulling a GS1572? From previous forums I don't think it would? I hate to go smaller as I plan on upsizing tractors a little later this summer. I hope they are as easy to run as everyone lets on. I have 0 experience with these. I want to maintain a 400' gravel drive and a 1/2 mile partial gravel drive. Thanks in advance for any insight.
/ Land Pride grading scraper #209
Should be no problem. Yours is only a little less powerful than my L3940 which has no problem with my GS1572.
/ Land Pride grading scraper #210
Hello everyone,
I hope I am not hi-jacking this thread I just thought why we are on the subject someone could recommend what size grader blade my tractor could handle.
I have visited quite a few tractor dealerships that maintain their gravel parking lots with a grader blade. And they comment they maintain
Other businesses parking lots once or twice a year with these blades.
I have seen some use a 48 wide, some a 72 wide, saw a 48 behind a very large CUT, I guess they use what tractor is available.
I need to decide between 48 in wide or a 60 inch wide for a Ford 1520 (23hp). I have a gravel drive but also I would like to try to take care of a few small parking lots.
For parking lots I am thinking wider is better? Land pride site list the
GS1548 for 20-50 hp and the GS1560 for 25-50 hp.
My tractor handles a 500lb. 60 inch box blade ok but I have never used a grader blade. I imagine two blades compared to a single box blade is a lot more drag but a box blade holds a lot more material.
Thanks for the help and interesting reading.
Johnny Walker
/ Land Pride grading scraper #211
Going to build a landplane coming up pretty soon, this thread has once again influenced me! I've got all the steal I need, but need to come up with a place for cutting edges, I'm going 72in wide and set the blades straight, but how long should my skids be? I'm curious. I'll be using I-Beams for the sides. And should I weld on a mount to put suitcase weights on it? Or will their be enough weight already?
/ Land Pride grading scraper #212
Hello everyone,
Johnny Walker
I pull a 60 inch grader behind my 21 hp Kubota, but I have to have the FEL on for the weight and traction. My 32 hp K handles the grader much better. If you don't have an FEL and 4WD you should probably go with the 48 inch unit. The grader does a great job of maintaining a parking lot. The grader will move some material, but not as much as a box blade. The grader is all about cutting down the high spots and filling in the low spots.
/ Land Pride grading scraper #213
We just bought a Land Pride Box Scraper :D
I asked for advise in the attachment section - nobody replied - so I went with my gut feeling. :D
Why is your bush hog drooping at the back? The tail wheel should be higher than the front of the hog during transport... and mowing. :thumbsup:
/ Land Pride grading scraper #214
I wouldn't build one that needs extra weights instead build one that is sturdy, ridgid and heavy duty. If you look at the pics I posted on pg 19 of this thread you will see I used beams and these are 5'0" in length. Works well but I would make them even longer if you can find the right length of steel. I bought two pieces out of the cut/scrap pile and this was as long as I could make the skids. You could make it with 6' skids and be in good shape imo.
/ Land Pride grading scraper #215
A 6 footer is going to be ALL that your tractor wants. If your main use is going to be road work, build the grader with the blades angled. Angled blades work best for removing wash board. Build the grader with heavy wall steel so that the weight and strength is built into the unit itself. You really want this implement to weigh well over 100lbs per foot width. 100lbs per foot is the absolute minimum IMO.
/ Land Pride grading scraper #216
Well it will defiantly will be rigid! I really like yours, and the low profile sides. I have the steel and it's all mostly in 20ft pieces so the length will be no problem, now did you ever want longer skids? I still don't know on a cutting edge, for first time I think I will just use and bolt on 1/4 flat steel. If it wears to fast I'll buy cutting edges, but I want to find out how well this works before I put too much money in it. It's going to be used on my CT235 and sometimes a 4120 Deere, first it's going to smooth up irrigation lanes then seed them, if good I'll use it on driveways. Do you ever want to add anything else to it to do better or is it good as it is?
/ Land Pride grading scraper #217
Ditto on the angled blades - They should definitely be angled.
Mine has depth-adjustable blades. I haven't ever adjusted them ... they're set at about 1/4" below the skids ... but if you weld them on & they're too shallow or too deep, you'd need to re-weld them - what a pain. Bolting them on would be better.
I kinda wish my grading scraper had a flap/ gate on the back that could be either in the 'up' position (not being used), or down to make the grading scraper act like a box blade. I don't have this gate now, & don't seem to really need it, but I thought it might be a neat addition, to drag a bunch of dirt at once.
/ Land Pride grading scraper #218
I was also thinking of a tailgate but I might put a skidsteer plate on back to push it with the T190. I'm also going to cut slots in the main to adjust the depth with bolts, I don't want angled I'm going to leave them straight. And the way I build stuff it won't be light. Jenkinsph landplane is almost exactly of want I want to build. How far apart should I put the blades?
/ Land Pride grading scraper #219
My blades look like they're about 15" - 18" apart.
/ Land Pride grading scraper #220
My blades are about 24 inches apart, I can check in the morning and post.
About the straight set blades, I felt for most of my work which is planing landscapes that the straight set blades were the best deal. I don't wan't the dirt to drift to one side or the other. I also have the blades set to 0 with the bottom wear strips. Since the plane is heavy it will still cut aggresively with a slight shortening of the top link. I can go a short distance and easily have dirt piled up under the tractor behind the rear wheels. That isn't the purpose of the landplane for my use though, if the ground is flat and smooth I want to move very little dirt. My thought is to cut off the mounds and fill in the depressions. I also have wider skids to reduce the gouging. Overall I am very satisfied with it for land planing in small to larger lawn areas.
For primarily road and driveway work angled blades would be preferred since you can tilt up the rear slightly and build a crown. I use a rearblade with topntilt to build a crown and recover material from the edges. I have had good success using the two implements together for roadwork. I do have the topntilt which allows me to raise one side of the plane slightly to help with sloping when needed. For roadwork I can see having the blades set lower to better mix the gravel and fines.
About the washboard areas, so far these seem to be dealt with easily and haven't noticed any issues or experienced any problems removing them.
About the DIY side of this project, if you think having adjustable depth is a real concern then an easy work around to address this problem would be to build the plane with the blades 1 inch below the skids. You could have pin on wear strips that would protrude upwards thru the flanges and use a hairpin clip to hold them in place. Have a set of thin wear strips 3/16 to 1/4 inch which would allow a net 3/4" setting below the skids and a 3/4 inch spacer wood strip to sandwich between when wanting to finish plane at the zero setting.
If you want to test this using flatbar in lieu of grader blades I would strongly recommend you drill the holes needed for the grader blades prior to assembly. It would be very difficult to drill these holes afterwards. Frankly I think all of us that have these implements will tell you to simply go for the grader blades to start with.
Last thing, Brian and I have talked about using these in reverse, both of us do. I have contemplated putting a hitch on the back end and then dragging it. Easy to drive forwards and safer for the hitch components too. Debating whether to do this or add the flip over tailgate with stops.
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2020 CATERPILLAR...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A65053)
2019 KUBOTA KX71-3...
New/Unused Deluxe Massage Chair (A65583)
New/Unused Deluxe...
2023 GERINGHOFF PATRIOT RD8R30" CHOPPING CORN HEAD (A64278)
2023 GERINGHOFF...
