New *&%^ EPA Fuel Containers
/ New *&%^ EPA Fuel Containers #43
Yeah, but Jegs has the same thing at about half the price. It is what I use (see previous post - #9).
Don't forget the $15 hose!
I linked direct to VP just so I didn't violate any advertising rules. If you search, you can find the full setups with hose cheaper.
ac
/ New *&%^ EPA Fuel Containers #44
gwdixon - I drill the hole for the valve & thread a home-built valve insertion tool onto the valve (metal valve cap with a length brass chain soldered to it), feed the small chain through the fill spout opening, turn can upside down & fish the chain out the small hole with a piece of bent wire, pull valve up through the hole. Remove core & you're done - looks factory!
I have read where others have added valve stems to their cans but never could figure out how to get the stem in from the inside of the can. Thanks Ken. I followed your lead and got two installed today. I used a cotter pin inserted in the valve tool, but otherwise followed your directions.
Works much better now.
pic 1 my "valve insertion tool"
pic 2 my can all fixed up
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
HARDEE L55 - 50 GALLON SPRAYER (A63291)
HARDEE L55 - 50...
HURRICANE (10) DRAWER (A64280)
HURRICANE (10)...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
Alliance Rear 16.9/14-38 Clamp On Rims (A64119)
Alliance Rear...
