3-Point Hitch n00bie st00pid PTO questions...
/ n00bie st00pid PTO questions... #21
Do all you guys actually turn the pto shaft to line up the bolt holes on the auger? I just turn the auger with my hand, not real difficult. ;) Intil you get your tractor figured out, best to always have it off when working around it.
/ n00bie st00pid PTO questions... #22
Depends on the equipment. When hooking up my rototiller, I need to turn the pto. With the mower deck, I can turn the driveshaft.
/ n00bie st00pid PTO questions... #23
What about while the PHD is on,can I just turn the auger by hand under the same conditions?
My concern really boils down to I am typically by myself when on the tractor, and I need to find a way to do all this stuff when alone...
David
Just a couple things I've learned to do by myself with the PHD. To change augers I lower it down to center but just off the ground, remove the pins and slide the auger back away from tractor to get off the shaft. Put other on auger on in reverse order the gear will stay close to that angle without quger on it, when auger is on the shaft and back to vertical lift the auger slightly and put pins back in.
I always carry a pipe wrench and short cheater bar with me when digging to use to turn auger backwards if it screws itself in the ground under a rock or tree root.
/ n00bie st00pid PTO questions... #24
Yes I would have Manuel hook it up. He may not speak good engles but he'll get the job done:laughing:
Yea, Thats too darn funny but you know, A lot of people just ask questions without ever reading the manual that came with thier machine. Most answers are in there, READ IT :p
/ n00bie st00pid PTO questions... #25
I know that it depends on what implements you are attaching to. The OP (David) was asking about a post hole digger and that is what I was talking about and mentioned the auger. ;)
/ n00bie st00pid PTO questions... #26
David,
Kioti Dk's have an independant PTO. The PTO brake engages when the PTO is turned off.
That is why you can't turn the tractors PTO stub by hand to hook up an implement.
I added a overunning clutch to my tractors PTO so I can turn it one way by hand.
Makes hooking up an implements PTO shaft a whole lot easier.
/ n00bie st00pid PTO questions... #27
I put my tiller on something so the tines are free to spin.
If not I hook it to the 3tph and lift it off the ground, turn the tractor off and then hook the pto up.
I usually turn the tractor off when hooking thing to the pto.. For two reasons.. One is safety, but the bigger reason is it usually takes me a few minutes to hook things up and I hate burning that much gas while I dink around with the pto.
Wedge
/ n00bie st00pid PTO questions... #28
Now I am not sure I even tried to hand turn it...
I need more coffee...
What I am hearing is...
If it is independant (which I believe it is) and the HST is in neutral, PTO not engaged, I should be able toi hand turn it at least in one direction.
Right?
David
It will only turn by hand with the engine OFF. Even though the PTO is not engaged there is still hydraulic pressure that will make it difficult if not impossible to turn by hand. ALWAYS, as a matter of good safety practices, turn the engine off before touching the PTO shaft. :thumbsup:
/ n00bie st00pid PTO questions... #29
On my DK45 i can turn the pto shaft by hand with the tractor off. You can also add an overrunning clutch (which i use on my rototiller and mower dur to shafts being too short) . This allows for real east freewheeling of pto.
A good overruning clutch had a hand detente to keep it attached and is easily removable. I didnt want the kind that perminantly attach.
/ n00bie st00pid PTO questions... #30
I never read the original thread about having tractor running or not running while hooking up pto but I just can't beleive that anyone would even consider hooking it up with the tractor running. My wife has some nasty scars on her legs from stepping over a running pto shaft when she was a little girl. A neighbour borrowed the grain auger and used a 5" spike bent over to hold the plastic guard in place. She stepped over it as she had done tons of times, the nail caught her dress and ripped her legs to shreds. 100's of stiches because it ripped pieces of skin away. I do enough stupid stuff so shutting off tractor while hooking up the pto is a no brainer.
GRS,
Where can I get one of those sir...
David
/ n00bie st00pid PTO questions... #32
GRS,
David
Ag supply among many places. But David don't forget that it adds about 4 or 5 inches to your PTO length, which means unless you PTO shaft on the grinder was cut a little short to begin with you may have to recut the the shaft to keep it from bottoming out and possibly damaging your PTO. When you grinder is raised on the 3pt is when the the shaft is usually shortest, check to see how much more the shaft can be collapsed. They can be easily cut, but you cannot lengthen them. Here is one link. I would try to find out if your PTO shaft can be turned at all by hand with the tractor off, or if the brake is going to hold it, or can the grinder be turned with a simple prybar like a long screwdriver run thru the yoke before I invested in an overrunning clutch and cut the shaft.
QD Overrunning Coupler 1-3/8" 6F X 1-3/8" 6M
/ n00bie st00pid PTO questions... #33
Of all the talk how bout the John Deere autohitch with the imatch!! Never have to get off and out of harms way!!! Lmao
/ n00bie st00pid PTO questions... #35
I got mine at BigR supply.. but any ag store carries them. I actually needed to add mine as my existing PTO shafts were too SHORT on the new DK45. They had all been cut to fit my old JD870, and were too short by a few inches to fit the new tractor. So instead of replacing all the driveshafts, i simply added this and everything works great.
but heed what the others said about shortening up the drive shafts too much. This lengthens the PTO spline by 6". In my case i didnt have to cut anything
greg
/ n00bie st00pid PTO questions... #36
Turn the tractor off.
If you have someone else in the driver's area with a running tractor while you're trying to hook up to the PTO, you're an obituary begging to be written.
I'd much rather have you sassing me out here for the next 10 years than to see a notice of death for you tomorrow.
That said, you could try slipping a foot long, 1/4 inch rod through the u-joint and turn the attachment shaft to line up the splines. Use a smooth piece of rod stock, not rebar, since rebar has ridges and can scrape things up.
/ n00bie st00pid PTO questions... #37
With my tractor, I have a pto selector to go from rear, mid and rear and mid only. I find that when changing to mid pto, I can spin the rear pto shaft freely, doesnt matter if engine is on or off. I always try to get into habit of changing pto selection opposite of what I am hooking up for a much easier hookup, with a added plus adding a safety margin. Does your kioti do the same?
I do not have a mid PTO, so I do not have that switch.
I am HOPING that what I am hearing is with the Tractor off I can turn the PTO shaft.
David
/ n00bie st00pid PTO questions... #40
David if you do wind up buying an overrunning clutch. be careful of what you buy, as many are not just over running clutches but adaptors to different spline sizes.. you need 1 3/8 6 spline on both the male and female ends.
James K0UA
2017 Chevrolet Equinox SUV (A61569)
2017 Chevrolet...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2004 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2004 V.E...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
832734 (A61166)
832734 (A61166)
