PTO for beginners
/ PTO for beginners #1
Torvy
Super Member
North East Texas
TYM T574H
OK, today's question from a beginner...I understand the basics of PTO, back in the days of my youth I helped out enough to know that a) PTO can be extremely dangerous and b) there are a lot of variables involved in using them.
My situation is such that I will not ever by a Snow Blower again. (I lived in the north for about 1/2 of my life and I don't miss the snow very often...the cold, I like)
In the tractors I am considering the PTO HP runs anywhere from 20 to 42. I think they all run at 540 rpm ,IIRC. They all have PTO, but there are differences.
I need help for me (and hopefully for other noobs) understanding what I want and what I need. Essentially, the pros and cons and uses of each type.
Also, I don't think I need a mid-PTO for my uses. As I mentioned, I will not be using a snow blower and I also have no use for a mid-mount mower as I will be doing no finish mowing at all. Are there other implements that typically use a mid-PTO that I should consider? (again, our 18+ acres is about 80% wooded, so anything to do with small-scale forestry and property maintenance is on my plate.)
Right now the list of possible implements to use with the tractor: Rotary Cutter, Post Hole Digger, Box Blade, Tree Shears and/or puller, small tiller, FEL with bucket and grappler. Outside chance we get a backhoe at some point.
Independent vs Live PTO....my recollection is essentially that with Independent you have a lever or switch that engages the PTO when you want it to run. Otherwise, it is effectively in neutral. Live runs when the engine runs and you use a 2-stage clutch to change gears with or without stopping the PTO depending on if you fully engage the clutch. So, experts, please clear up any misunderstandings I have on this and give some pros/cons for why one or the other is better.
Thanks!
/ PTO for beginners #2
I don't think I need a mid-PTO for my uses. Our 18+ acres is about 80% wooded, so anything to do with small-scale forestry and property maintenance is on my plate.
Working in woods a mid-PTO is an encumbrance subject to damage.
Your understanding is perfect.
Mowing thick brush or tall grass with an independent PTO it is often useful to use full throttle to power the mower, while slowing forward progress of the tractor.
When using a roto-tiller you may want 1/2 to 3/4 power to the tiller, depending on tiller weight and width, while creeping forward with the tractor. HST is ideal for roto-tilling.
About 90% of compact tractors are sold with HST transmissions. I believe HST transmissions are always paired with an independent PTO.
Two things that impair the resale value of a compact tractor are a traditional clutch-and-gear transmission and the absence of a Front End Loader.
Order an optional $75 rear/center drawbar, buy a clevis grab hook for the drawbar, ($24 at Tractor Supply) and 5/16" grade 70 chain in 8' + 12' lengths, with a 5/16" chain grab hook on one end and a 5/16" chain slip hook on the other end, for towing trees. Infrequently you will join the two chain lengths.
No compact tractor I know of has the weight to effectively use a tree shear, which are skid steer tools sometimes used on 6,000 pound + bare weight tractors.
A Bucket Spade can be very useful on a 4,000 pound bare weight tractor.
/ PTO for beginners #3
My concerns were - obtaining implements of the proper size to match the PTO hp.
/ PTO for beginners #4
Are you considering a new, or antique tractor? Most new(ish) tractors all have live PTO, and most also have a mid-PTO. Live/Independent PTO is awesome - insist on that (I may have the names mixed up - but you do not want to have one that requires the trans to be in gear and clutch out - to operate). If you have, and don't use, the mid-PTO, that's OK. The grapple and tree shear options may require some extra hydraulics. PTO horsepower rating is an indication of the strength of the gearbox and HP needed to properly run it well. Look at the Cat rating of the 3 point, so all of your attachments can be run w/o messing with bushings.
/ PTO for beginners #5
You want independent PTO. Live and transmission driven PTO are a thing of the past as far as I'm concerned. When I engage my PTO it is similar to a soft start motor in that it feathers in. I still rewduce RPM prior to engaging and disengaging. My new flail mower has free wheel built in so it doesn't affect the clutch on my PTO.
/ PTO for beginners #6
What tractors have live PTO? All JD tractors I can think of or know of have a switch or lever to engage the PTO independent of the transmission clutch.
/ PTO for beginners
My plan is to do it the other way around. Once I fully determine what implements I am going to need/want, then I will see if I can find a tractor that is capable of handling the load. Of course, there is always the 'next best thing' but I think I will be busy enough to live within my means and ignore most of that...besides, the home boss manages the purse strings.
/ PTO for beginners #8
Some lower end Kubotas have live PTO. I'm sure there are others.
The independent PTO is handy if you will be running a PTO chipper or other stationary implement. You can turn the PTO on and off while standing next to the tractor rather than having to get on to operate the clutch.
540 rpm is the standard PTO speed in the US for compact tractors and their implements. Some tractors and implements in Japan used 1000 rpm. 1000 rpm is also common for larger ag tractors. Some compact tractors have two speed PTOs with one 540 and one a faster speed like 750. The faster PTO speed lets you run the engine slower to get 540 at the PTO. That can be useful for operating implements that don't need full power, letting you run quieter and save fuel. My Branson has a two speed PTO. The tach is marked for 540 PTO rpm for each speed.
/ PTO for beginners #9
Kubota L2501 with gear transmission. L2501 is one of Kubota's highest volume models in USA. Many in central Florida are sold as "mowers" with 2-WD and traditional clutch & gear transmissions in combination with a 'live' PTO.
/ PTO for beginners #10
Settle on your tractor first.
As you recognize new needs research implements carefully and buy them one at a time. T-B-N is a good place to research.
Your tractor knowledge base and operating moxie will expand even if you operate but one implement.
/ PTO for beginners
The 30 'D' series compact tractors from JD have transmission driven PTO. It seems like the bigger or HST versions may have independent PTO. Kubota is similar, those less than about 35 HP seem to be more likely to be 'live' PTO and the larger or HST models seem more likely to be independent...similar results with Kioti. I am currently limiting my search to those who have dealers within about an hour of the property (JD, CIH, Kubota, Kioti, Bobcat, NH)
/ PTO for beginners #12
Both of these are somewhat incorrect. One of the best selling lines, the kioti ck10 series (including the 2610 which is dominating the 25hp market) are all live in both gear and hst models
If you upgrade to the SE model you get electronic pto/independent control.
/ PTO for beginners #13
The tree spade (if that is what you mean by tree puller) will likely be your deciding implement as it is based on the size of tree you expect to pick up without killing it.
The bigger the trees, the larger 3 point you need and more hydraulic flow as you pick up a substantial amount of ground in addition to the tree and have to drive the wedges. (They do make a loader mounted version as well - both need considering what you are using for counterweight).
If you mean the arm attached to your loader, then it is a matter of loader strength which is size or class based.
/ PTO for beginners
I was thinking of something like this (from Messics website):
Or this (EZ puller by CL Fabrications):
I don't think we will be doing a lot of transplanting. If so, it would be smaller/younger trees.
The advantage to the FEL shear is that you can use it to prune low branches as well as cut down small trees (mostly for thinning our pines or removing unwanted species).
/ PTO for beginners #15
So the tractor in the second image is 95-100hp for that example/staging, the loader is 1300-1800 lbs lift strength.
If that is your method of choice for removing trees (we dig them out or cut and use a stump grinder here), you will need something sized for the work.
/ PTO for beginners #16
Thanks!
- There are three standard rear PTO specifications, 1 3/8" 6 spline shaft 540 rpm, 1 3/8" 21 spine shaft 1000 rpm, and 1 3/4" 20 spline shaft 1000 rpm. Essentially everything designed for the U.S. domestic market under about 75 engine HP is going to be the standard 540 rpm setup only, so you won't see anything else unless you are looking at a larger tractor or some foreign market tractor. You won't likely encounter any implements except a mid mount mower or snowblower (most of them run at 2000 RPM) that don't use a 540 RPM PTO as implements with a 1000 rpm PTO are designed to take at least 75-100 PTO HP to run.
- Typically a mid mount PTO is used to run a mid mount mower. Theoretically you could run a hydraulic pump or something similar off of a mid mount PTO like a pickup with a transmission PTO would, but nearly all of that type of equipment for tractors just runs off of a rear PTO as mid mount PTOs are proprietary and would be not profitable to design for.
- There are three types of PTO clutches, transmission-driven, live, and independent. Transmission driven is what most tractors before about 1960 used and is what some of the smaller gear-transmission compact tractors like the Kubota L2501/L3301 and Deere 3D series. The PTO runs off of a gear inside of the transmission and you can either engage the gear and have the PTO turn or leave it in neutral and have the PTO not turn. If the PTO is engaged, it turns whenever the main traction clutch is engaged and it stops when the main traction clutch is disengaged. You can run a stationary piece of PTO equipment like a post hole auger, chipper, or generator with a transmission PTO, simply put the transmission in neutral, parking brake engaged, and with the PTO engaged let out the clutch.
- Live PTOs use a two-stage main clutch pedal where if you push it in partway, it disengages the traction clutch but the PTO clutch is still engaged, and if you push it in all of the way, you disengage both. The PTO itself has an engage/disengage lever where engaged engages the gear to the clutch shaft and disengages leaves it in neutral. This was seen on many tractors from about the 1960s to the 1980s and is still seen on some smaller gear-driven compact tractors like the Kubota L3701. You have the advantage here of being able to stop the tractor with the PTO still turning and it allows for a synchronized transmission to be practical.
- Independent PTO is what most tractors today use and it uses a completely different clutch from the main traction clutch. The entire PTO setup is clutched and if the clutch is engaged (either by a mechanical lever or by an electronic/electrohydraulic solenoid) the PTO turns, and if the clutch is disengaged, the PTO doesn't turn.
- Tractors with a hydrostatic drive effectively all behave as if they have an independent PTO, even if mechanically there may be a clutch on the engine to control the PTO and also drive the hydrostatic pump. If there is such a clutch setup, you don't use it to stop, shift, or change directions, so it behaves like an independent setup on a gear drive tractor.
An independent PTO is the easiest to use as it's the most "fool-resistant," simply engage when you want the PTO to start to run and disengage when you want it to stop. You will learn to not step "too far" on the clutch with a live PTO when shifting but once you do so, a live PTO works just as well as an independent. A transmission driven PTO will make you alter how you work with a PTO-driven implement as your PTO implement nearly always takes longer to spin back up after clutching than your tractor takes to resume moving. You will either work in a way so you can avoid clutching (e.g. making larger headlands where you can simply turn around rather than making a 3 point turn) or accommodate the added distance needed for the implement to spin back up before you get to where you need to resume working. Depending on what you are doing and how much you are willing to learn, this may be no big deal or a bit of a hassle.
I personally vote for an independent PTO on a gear transmission tractor but would be happy with a live PTO on a gear transmission as well. I would get a different model/series or brand of tractor if I had to get a transmission driven PTO to get a gear transmission instead of a hydrostatic drive. These aren't generally an option on compact tractors unless you pick between different model lines, but I prefer a mechanical PTO clutch engagement over an electrohydraulic engagement and prefer a mechanically-controlled transmission clutch instead of a solenoid-controlled unit such as a powershift or hydraulic reverser as I can feather engagement with a mechanical linkage but am at the mercy of a computer for an electrohydraulic solenoid to avoid it just abruptly dropping the clutch.
/ PTO for beginners
Wow! Thank you! I feel like I should be preparing for a quiz (in a good way). That was a very good and detailed, yet understandable explanation of how it all works.
What I think I prefer at the moment is a gear transmission and an independent PTO. Maybe something like the L4701 by Kubota. 4WD gear transmission and independent PTO. It is also on the middle of the compact tractors. For what I need, too big may be a problem.
It seems like a Live PTO might mess with my 'muscle memory' when driving a manual transmission car or truck.
/ PTO for beginners #18
Not just a good explanation, but good recommendations as well.
thumbs up.
/ PTO for beginners #19
How large of a tractor you need or want depends on what you intend to do with it. You mentioned a few implements but if you let us know some specific jobs you intend to do we can help you out. You can easily buy too large as easily as you can buy too small. A Kubota L4701 is on the larger side of the compact tractor spectrum, a subcompact like a BX is on the small side of that spectrum.
Various things can mess with "muscle memory," the worst for me is using a tractor with a hydraulic reverser transmission. I always initially shift into some incorrect forward gear instead of using the reverser lever to reverse as my tractor has a standard synchronized transmission without a hydraulic reverser so reverse is on the regular gearshift lever. I then generally use it without problems but then when I get in my truck to leave, I invariably turn on the right turn signal or flip on the high beams of my truck when I actually wanted to back up.
/ PTO for beginners
Mo1, that is a good point. We are still compiling a full list of tasks, but there are some that are 'must have' and some that are 'nice to have'.
Must have -
rotary cutter (total of maybe 3-4 acres out of 18.5 are going to need to be rough cut periodically);
FEL (between moving fallen branches/trees and road/path maintenance that is a given);
box blade or similar (our driveway will be about 200+ feet of gravel/rock base, we also have a couple of extra approaches into the property that will need maintenance);
Nice to have -
Post hole digger - not sure if rent or own, but we need to fence at least 1/2 the property and it may be a good option for planting new trees. (we will be planting some fruit/nut trees in one area and will likely start a very small Christmas tree 'farm' in another)
Forestry related equipment Not sure what else we will need (shears/chipper/puller?), we have 14-15 acres of just trees, mostly loblolly pines that can be harvested for timber. We need to thin the trees of scrub and such and remove deadfall and low branches. We MAY decide to harvest pine straw as well. I thought about baling hay in my open areas, but that may be cost prohibitive. Ultimately, we are not trying to turn a profit, just defray the cost of our equipment and give back to the community (the Christmas trees will be a donation thing).
