3-Point Hitch n00bie st00pid PTO questions...
/ n00bie st00pid PTO questions... #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Guys,
I hate to ask, but is there a neutral on the PTO?
It seems shockingly dangerous to have my wife "bump" the pto with someone (me) trying to line up the gears on the attachment so it will slide on. :shocked: I will admit I was skeert...
Similarly, on the PHD, to change augers, I need to bump the PTO until the bolts and holes line up, and this must be done twice.
What am I missing? :confused2:
What went over my head (or I fell asleep) while reading my owners manual?
I'm not a dummy, but my tractor sure makes me feel like one pretty often...
Thanks in advance,
David
/ n00bie st00pid PTO questions... #2
Everyone I have used, the PTO will turn by hand if not engaged. I have never fooled with a Kioti, but I don't see why it would be any different. Having to bump it to line up don't sound too fun. I hope you did not make her mad that day.:laughing:
/ n00bie st00pid PTO questions... #3
IF you are talking about your kitoi, it "should" have an internal overrunning clutch, if it is not an independent PTO.
That means you should at least be able to turn it one direction.
Some of the older tractors with transmission driven ptos were not that way however. But with tractor in neutral, it should still turn.
/ n00bie st00pid PTO questions... #4
You should have a selector for the PTO, usually you can select mid, rear or both. Move the lever to the mid position not only prevent the PTO from turning on, but it also turns off the brake on the rear spline so you turn it by hand to help with final alignment.
/ n00bie st00pid PTO questions... #5
David , When I hook up to my pto , I turn the pto shaft on the equipment by hand to line up , does not always work . So I prefur to cut the tractor off and then turn the pto by hand . " grab the pto shafts at the end by the ends , not the plastic sheilds " Hope this helps , be safe . Steven
/ n00bie st00pid PTO questions... #6
It sounds like you are trying to hook something to the PTO or change augers on the PHD with the engine running. As mentioned above, mine has a neutral position where it does not run and you can turn it by hand, but I still would not hook something up to the PTO without shutting the engine off, with or without anyone in the seat. It seems like a small step to take to insure all of your body parts are going to be with you at the end of the day.
Now I am not sure I even tried to hand turn it...
I need more coffee...
What I am hearing is...
If it is independant (which I believe it is) and the HST is in neutral, PTO not engaged, I should be able toi hand turn it at least in one direction.
Right?
What about while the PHD is on,can I just turn the auger by hand under the same conditions?
My concern really boils down to I am typically by myself when on the tractor, and I need to find a way to do all this stuff when alone...
David
That is exactly my fear/plan.
I want to keep all my various parts intact and working properly!
David
/ n00bie st00pid PTO questions... #9
What does the manual say?????:p
/ n00bie st00pid PTO questions... #10
I have a 'nuetral' position on my pto. But as others have suggested, try turning the tractor off to hook up the pto.
Nothing beats a 'try', but a 'failure'.:thumbsup:
/ n00bie st00pid PTO questions... #11
On my CK20HST, the rear PTO can be turned by hand. When I connect the driveshaft from my snowblower attachment, I typically need to turn the rear PTO to line up the spline teeth. The PTO spins freely and easily. Of course this is with the PTO in the OFF position and with the engine running at idle. Also the HST stays in LOW or HIGH gear, no need to put it in NEUTRAL. I'm not sure if yours is the same but on mine there is two levers for the Mid and Rear PTO's, just on and off.
/ n00bie st00pid PTO questions... #12
Right?
David
Engine off is what you are not hearing. I generally can turn the implements drive shaft to line up with the PTO's spline gear as I have never even thought of grabbing and turning the spline, while engine is off and pto is disengaged (neutral) even my old Harvester had a lever to put the PTO into neutral. Doing it with her running let alone bumping? makes certain body parts shrink, lol. If you give year and model of your tractor someone here will have the same and will be able to explain.:thumbsup:
/ n00bie st00pid PTO questions... #13
Engine off is what you are not hearing....
Just in case you didn't hear it the first time. :D n00bie = engine off.
Also, personally, I don't like hooking something up with another person... learn to do it by yourself. It's an accident waiting to happen...
/ n00bie st00pid PTO questions... #14
The DK50 uses an electric solenoid to send hydraulic pressure to the PTO clucth, it is not a good practice to trying to hook up with engine running let alone trying to bump the tractor PTO.
/ n00bie st00pid PTO questions... #15
Dave,
Lots of good advice on here
1) Engine Off
2) 1 person in the seat and 1 person on the ground is generally less safe than turning the tractor off and setting the brake.
In any event, your PTO should have enough play with the engine off to wiggle back and forth enough to line the splines up.
On technique I use, however, is to put a bar or something between the universal joint on the yoke of whatever implement I am trying to connect. Using that technique, I have been able to turn my haybaler, haybine, and batwing several degrees in order to line up the splines. You may find that to be easier. You definitely have more leverage. The smaller stuff, I can just turn with my hands. And, most implements will rotate either way, in case you over shoot. Now, I will say, use caution and turn slowly. I can get my batwing to rotate with my bare hands. However, once I get it (20' with 3 spindles) moving, inertia will cause it to continue to rotate another 3/4 turn or so.
Hawk
/ n00bie st00pid PTO questions... #16
I usually just tip the U-joint on the PTO shaft so it is bent over at 90 degrees and use it as a crank to rotate the implement a hair. Only tractor I ever shut-off to connect the PTO was the old 5000 Ford because the brake was shot and it never stopped spinning without some load on it.
I would say do what YOU are comfortable doing, after all, it is your body parts that are going to be scrambled, not mine...
Roy
/ n00bie st00pid PTO questions... #17
There was an EMT on here a while back and posted some graphic descriptions of some fellas that were PTO casualty's. This was in a PTO hookup with engine running or not thread. While I have hooked up the PTO with the tractor running I have stopped doing it after reading about these poor armless guys wrapped around a PTO drive shaft. And another thing with the new electric/hydraulic actuators you are trusting an electrical connection/switch to not actuate the PTO while your hand is on it.. no thank you. I have seen a lot of electrical failures in my time. Best to have the engine off, and I agree the best situation is to do it all yourself as you are in total control. I have always been able to roll the implement shaft a little to get lined up, but I would think a screwdriver or something to use for a little leverage would work if your implement was to hard to turn by hand.
James K0UA
/ n00bie st00pid PTO questions... #18
Probabally not because ot the reduction of the gearbox, plus the overcoming the angle of the u-joints in the PTO shaft. In the case of trying to spin the auger by hand, is like reverse gear reduction.
Think about it this way, jack up one rear tire on your truck, and turn the wheel. It will spin the driveshaft, which is exactally what you are trying to do if trying to turn the auger by hand. Only take the tire off and try spinning by the smaller diameter axle or brake rotor/drum.....much harder.
And I dont have a kioti, but on my 'bota 3400, my PTO will free spin in any direction as long as it is disengaged...EVEN with the tractor running.
Gear tractor, live PTO/2-stage clutch BTW.
Even with engine running, I would think you could spin the PTO as long as it isnt engaged. I do it all the time hooking up my implements.
/ n00bie st00pid PTO questions... #20
James K0UA
I remember that thread...pretty graphic.
I'm also one who only hooks up or disconnects when the tractor engine is off. I know there was a lot of discussion on this...some pretty heated. Well, I do what I do...and nobody is going to change my mind.
BTW, most of the time, not only is the engine off, I also have the tractor's key in my pocket.
