10" front rims for X495
/ 10" front rims for X495 #1
Catmancoop
Peoria, IL
John Deere X495
Hi everyone, new to the forum and have a question. I have a X485 that I purchased recently and need new tires. I really like the Carlise Field Trax HD tires. I can get 26x12-12 for the rear, but I can't find a 16x8.50-8 size for the front. There is a 16x8.50-10 size available, which could work if I could find a 10" rim for the 2wd front axle. Any ideas?
Thanks in advance.
/ 10" front rims for X495 #2
Yes. In addition to the 10" rims you also need to purchase the hubs for your front axle. The 10" rims bolt on to the hubs that slide on to the spindle, whereas the 8" rims slide directly on. The later model SE units come equipped with what you want.
I think you mean 18-8.50-10 fronts, right?
/ 10" front rims for X495 #3
catman
Do you have the X495 or X485? Both were mentioned, one must be a typo.
Btw, thanks Xskier for the info. Anyone ever done this?
Also, I mowed today - 50+ degrees in January - can you believe it!
The x495 / 62C / Powerflow works like a dream. Gotta love the diesel! :thumbsup:
/ 10" front rims for X495 #6
If you get the 5 hole hubs and 10" rims it will look just like my X720SE.
Yup, that is just the look I want! I'll have HDAP's front and rear.
Just gotta get part numbers for the rims and hubs. The JD site is so difficult to find parts.
/ 10" front rims for X495 #9
Just call a JD dealer and they can get them to you in a second. Just tell them you want the hubs and caps for a X720SE.
Make sure you post some pics of it when your done!!!
/ 10" front rims for X495 #10
He is correct, but to give you an idea of cost:
M144698-Bolt, Wheel, Qty 10-$11.40
AM140109-Hub and flange assembly Qty 2-$189.28
M150676- wheel, 10x6, spl ed-Qty 2-Qty 2-$144.88
Total Cost without tires- $345.56
If you do not want the mismatched wheels, the rear SE wheels will have to be ordered. I think they cost about $205.00 for a pair. I'm guessing the total cost would be around $1000.00 with tires, just a guess,though. The rear tires M156433 HDAP are $384.80 through a dealer. I'm having trouble finding the front HDAPs
/ 10" front rims for X495 #11
It's not about the money, it is how it is going to look. :)
Thanks for the help. The tractor came with bar tires on the rear. I bought 2 used rear rims for $100. Already ordered the rear HDAP's online. I would prefer the fronts without the extra holes in the SE rims. Would the std 4wd front rim work?
/ 10" front rims for X495 #13
I do not know the offset is different, the other specifications seem the same.
/ 10" front rims for X495 #14
Yes the std. 4wd rims are what you want to match your rears.
/ 10" front rims for X495 #16
Thanks in advance.
I replaced the original 18x8.5x8 with the 18x8.5.10. rims and tires. John Deere dealer will have all the hardware numbers you will need. I didn't want to mess with it so I had the dealer make the switch. Took about a half hour. Did the change on site in the box bed of the service truck. I have attached a picture of my X485 with the 10' rims.
You mentioned 16" rims on the front of the X485 I think they come standard with 18' rims.
/ 10" front rims for X495 #17
Hardscrabbler. Where did you get your ROPS? And do you know if it will fit a X728
/ 10" front rims for X495 #18
I got my ROPS at FEMCO Company. They are located in Kansas. You can visit their website. I think the frame for the X728 may be the same as the X485. If so it should bolt right on. You may have to contact FEMCO to determine if they have a ROPS that will fit the X728. I have heard rumors that they have discontinued this ROPS model.
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A66736)
2021 Chevrolet...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
2003 Johnson 50hp 4-Stroke Outboard Boat Motor. (A66738)
2003 Johnson 50hp...
2011 Cub Cadet 42in Riding Lawn Mower (A66738)
2011 Cub Cadet...
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
1457 (A65054)
1457 (A65054)
