Buying Advice May have found my first tractor
/ May have found my first tractor #1
Giesetraveler
St. Paul, Property No. Central MN
Ford 5000 gas
Thanks to the folks this Fall that gave me input on a tractor.
I have about 30Ac tillable, 40 timber, another 20 low flood plain, none worked for decades. Sandy loam with lots of volunteer poplar, birch, tamarack, spruce, white and red pine and of course tag alder. plan to start tilling open areas and to take back some territory.
I am looking at a used mid 70's Ford 5000 gas. My local dealer took it in trade because the owner needed a slower reverse gear for his snowblower.
The dealer has serviced this rig for the last several years so knows it. Apparently he was told there may be some pto issues so he said he would go over it. He thought it would sell for 6K-6500 with original big front bucket.
Based on what I have seen here and other sites this seems like a reasonable price. I just used the dealer for some other hydraulic work and they were good and fair. He also said I could give it a try to make sure it was what I was looking for.
I had originally looked for a 30-40 hp CUT with FEL but based on comments think a 65 hp heavier rig will be a better rig all around.
Any input to this newbie would be greatly appreciated. Thanks
/ May have found my first tractor #2
You ought to take him up on that. A trial on your property would be ideal.
If it performs well, and is in good shape, you're getting into a tractor for a pretty reasonable price.
Good luck!
/ May have found my first tractor #3
ford 5000 in my area go for about 5000$ for a diesel 8spd.
hmm.. needed a slower reverse gear?? odd.
the 8spd tranny has 2 reverses.. one is a crawl....
pto issues?
check that. it's a hyd activated pto.. if pressur eis low or the clutch pack is worn.. it will be a decent repair bill.
soundguy
/ May have found my first tractor #4
If your plans are to start working ground, you will be much more happy with the 5000 than a 35 hp compact. The 5000 is to a compact, as the compact is to a lawn tractor.
I have done my share of snowblowing with the 8x2 trans.. Low is plenty slow and high is pretty fast. The problem is the lack of gears inbetween. Doing a long drive in low can be a drag, and you feel like a fighter pilot in high. Maybe that is what the guy was trying to say???
Thanks for the info all
In central MN anything in the 65hp class in diesel if you can find them seem to be more here.
Don't know why
You are probablt right about the wide range between low and high. Long drives with lots of in reverse I can see the need for a little middle ground
/ May have found my first tractor #7
Couple of things that would concern me... 2WD and gas.
I have been back and forth regarding a higher Hp tractor that would be a backup hay tractor and snow removal/loader machine.
There's some very good deal's on the 5000 frame sized machines. But... everytime I've used a 2WD tractor moving snow and cleaning the corral during the winter - I end up gettin' stuck and having the front end slide all over creation! PITA! Even with chains.
Unless it was a real low-hour gas machine - I'd pass. I appreciate the long-life of a diesel engine and the better fuel economy.
Guess that the higher torque (when the baler slugs into a heavy spot in the windrow) doesn't hurt, either.
My $0.02
AKfish
/ May have found my first tractor #8
with large loaded and chained? tires and diffy lock.. IMHO.. 2wd on a largish tractor ain't so bad.
gasser might start a hair easier in arctic.. but the pto issue is what would make me look it over REAL good first..
/ May have found my first tractor #9
pto isn't to bad to repair on a 5000 as long and the clutch pack housing is cracked you can replace all seals plates and orings with labor for around 750 to 900 this is what i charge atleast
/ May have found my first tractor #10
that's my point. it's ot a cheap repair.. near 1g$ he's already looking at paying premium money for a 5000.. he needs to think about the possibility of a 800$ repair. or more $$$ if the dealer does it.. like maybee 2-3x as much.
I did the hyd ind wet clutch pack on my step dads jd 2240 a while back.
parts were 600$.. oil another 120$.. 2 days of my free labor etc.. etc. plus incedentals like cleaning supplies and a line or fititng or 2 we broke splitting her.. etc.
oh yeah.. (1) 50$ shop charge to pack/unpack a spring compressed pack apart..e tc.
all adds up.
if the op can do his own wrench work.. not bad..
soundguy
/ May have found my first tractor #11
all adds up.
soundguy
i was just saying don't let the pto be a deal killer the gas motor would be my biggest concern a good diesel 5000 can be had nowadays for around 4000
/ May have found my first tractor #12
whodat - might share a "hot tip" on that 2240... :D Likely don't have a pto question there?
AKfish
/ May have found my first tractor #13
also my point.. he's paying 'premium mony' for a non premium machine.
I bet a gasser 5000 can eat a hole in your wallet FAST if you are really working her.
I'd hate to have to mow or soemthing similar with a 70hp machine.. :)
/ May have found my first tractor #14
AKfish
yea the 2240 doesn't have a pto problem no problems for that matter low hour and as you stated in the other post it is a cherry i have never seen one in my area in as good of shape as this one is and i am only asking 10500 and it low hour and has like new rubber no leaks 1 set of factory remotes you couldn't find a nicer 25year old tractor
/ May have found my first tractor #15
yes it will be a thursty tractor and i would hate it if the carb ever started having any trouble
/ May have found my first tractor #16
or the manifold.
seen a gasser 5k manifold lately :) one that wasn't made from parts and welding.. :)
/ May have found my first tractor #17
or the manifold.
i know they are hard to find no longer serviced and if you do find one that is repaired any where they aint cheap i had to give 250 for a like new one last year for a customers tractor i was working on a diesel one isn't but 50 bucks used
/ May have found my first tractor #18
yep. a few years back one of the farm magazines showed a guy that made a gas manifold using parts and pieces.. literally a 'make-up' as he couldn't find one.
soundguy
/ May have found my first tractor #19
soundguy
i have seen stranger stuff done to some tractors that the parts are hard to find. i have a buddy that keeps having trouble with the sleeves leaking on a 188 case motor in his dozer so he both a old 4000 prior diesel and is putting the motor out of it into his dozer now
/ May have found my first tractor #20
neat repower
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
