Buying Advice May have found my first tractor
   / May have found my first tractor #11
that's my point. it's ot a cheap repair.. near 1g$ he's already looking at paying premium money for a 5000.. he needs to think about the possibility of a 800$ repair. or more $$$ if the dealer does it.. like maybee 2-3x as much.
I did the hyd ind wet clutch pack on my step dads jd 2240 a while back.
parts were 600$.. oil another 120$.. 2 days of my free labor etc.. etc. plus incedentals like cleaning supplies and a line or fititng or 2 we broke splitting her.. etc.
oh yeah.. (1) 50$ shop charge to pack/unpack a spring compressed pack apart..e tc.
all adds up.
if the op can do his own wrench work.. not bad..
soundguy
i was just saying don't let the pto be a deal killer the gas motor would be my biggest concern a good diesel 5000 can be had nowadays for around 4000
   / May have found my first tractor #12
whodat - might share a "hot tip" on that 2240... :D Likely don't have a pto question there?
AKfish
   / May have found my first tractor #13
also my point.. he's paying 'premium mony' for a non premium machine.
I bet a gasser 5000 can eat a hole in your wallet FAST if you are really working her.
I'd hate to have to mow or soemthing similar with a 70hp machine.. :)
   / May have found my first tractor #14
AKfish
yea the 2240 doesn't have a pto problem no problems for that matter low hour and as you stated in the other post it is a cherry i have never seen one in my area in as good of shape as this one is and i am only asking 10500 and it low hour and has like new rubber no leaks 1 set of factory remotes you couldn't find a nicer 25year old tractor
   / May have found my first tractor #15
yes it will be a thursty tractor and i would hate it if the carb ever started having any trouble
   / May have found my first tractor #16
or the manifold.
seen a gasser 5k manifold lately :) one that wasn't made from parts and welding.. :)
   / May have found my first tractor #17
or the manifold.
i know they are hard to find no longer serviced and if you do find one that is repaired any where they aint cheap i had to give 250 for a like new one last year for a customers tractor i was working on a diesel one isn't but 50 bucks used
   / May have found my first tractor #18
yep. a few years back one of the farm magazines showed a guy that made a gas manifold using parts and pieces.. literally a 'make-up' as he couldn't find one.
soundguy
   / May have found my first tractor #19
soundguy
i have seen stranger stuff done to some tractors that the parts are hard to find. i have a buddy that keeps having trouble with the sleeves leaking on a 188 case motor in his dozer so he both a old 4000 prior diesel and is putting the motor out of it into his dozer now
   / May have found my first tractor #20
neat repower
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
