Buying Advice May have found my first tractor
   / May have found my first tractor #11
that's my point. it's ot a cheap repair.. near 1g$ he's already looking at paying premium money for a 5000.. he needs to think about the possibility of a 800$ repair. or more $$$ if the dealer does it.. like maybee 2-3x as much.
I did the hyd ind wet clutch pack on my step dads jd 2240 a while back.
parts were 600$.. oil another 120$.. 2 days of my free labor etc.. etc. plus incedentals like cleaning supplies and a line or fititng or 2 we broke splitting her.. etc.
oh yeah.. (1) 50$ shop charge to pack/unpack a spring compressed pack apart..e tc.
all adds up.
if the op can do his own wrench work.. not bad..
soundguy
i was just saying don't let the pto be a deal killer the gas motor would be my biggest concern a good diesel 5000 can be had nowadays for around 4000
   / May have found my first tractor #12
whodat - might share a "hot tip" on that 2240... :D Likely don't have a pto question there?
AKfish
   / May have found my first tractor #13
also my point.. he's paying 'premium mony' for a non premium machine.
I bet a gasser 5000 can eat a hole in your wallet FAST if you are really working her.
I'd hate to have to mow or soemthing similar with a 70hp machine.. :)
   / May have found my first tractor #14
AKfish
yea the 2240 doesn't have a pto problem no problems for that matter low hour and as you stated in the other post it is a cherry i have never seen one in my area in as good of shape as this one is and i am only asking 10500 and it low hour and has like new rubber no leaks 1 set of factory remotes you couldn't find a nicer 25year old tractor
   / May have found my first tractor #15
yes it will be a thursty tractor and i would hate it if the carb ever started having any trouble
   / May have found my first tractor #16
or the manifold.
seen a gasser 5k manifold lately :) one that wasn't made from parts and welding.. :)
   / May have found my first tractor #17
or the manifold.
i know they are hard to find no longer serviced and if you do find one that is repaired any where they aint cheap i had to give 250 for a like new one last year for a customers tractor i was working on a diesel one isn't but 50 bucks used
   / May have found my first tractor #18
yep. a few years back one of the farm magazines showed a guy that made a gas manifold using parts and pieces.. literally a 'make-up' as he couldn't find one.
soundguy
   / May have found my first tractor #19
soundguy
i have seen stranger stuff done to some tractors that the parts are hard to find. i have a buddy that keeps having trouble with the sleeves leaking on a 188 case motor in his dozer so he both a old 4000 prior diesel and is putting the motor out of it into his dozer now
   / May have found my first tractor #20
neat repower
2015 Freightliner Cascadia SLEEPER (A58017)
2015 Freightliner...
24in pin on excavator tooth bucket (A56435)
24in pin on...
2021 Caterpillar 300.9D Mini Excavator (A55973)
2021 Caterpillar...
40 ft. Shipping Container (A55973)
40 ft. Shipping...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
