REMINDER - Ice is very slippery!
/ REMINDER - Ice is very slippery! #1
DMax2210
Northern Maine
2011 JD 2520
As some of you may be well aware, New England (specifically northern Maine) received a fair amount of freezing rain over the weekend, leaving all surfaces in a nice coating of ice. After things quieted down Sunday morning, I decided that I'd see if the box scraper could drag some salt/sand from what had been plowed at the edges of the driveway, around the yard enough to scrape up the surface and make it a bit more passable. As you can see from the first picture, it worked fairly well - I was pleased with the results and it made a decent surface to walk on and drive across. The forecast called for warm temps the next day, so I anticipated it melting quite a bit anyway (as I write this I can see that most of the driveway is bare again :thumbsup:).
So feeling pretty good about my results and the tractor doing a nice job, a part of my brain, that I apparently should not listen to, decided that it would be a good idea to head down the gravel driveway to the back sheds, and see if the box scraper could rough up the surface enough to make it more passable. Now, to paint the picture, I've got the 2520 set up with the cab on it, snowblower on the front and box scraper, without scarifiers, on the back - NO CHAINS. My driveway that I mainly clear is in the first picture - nice and flat and really no need for chains, even with the R4 tires. As I mentioned, for some reason I had thought this was a good idea...... right up until the second that the front tires hit the gravel surface and went over the edge of the hill...... The weight of the tractor shifted forward and the sliding began! I quickly dropped the box scraper to the ground, followed by the blower - making any attempt at all to stop the slide. Unfortunately, neither was helping and I was headed towards an embankment (fortunately ROPS up and locked with seatbelt on!). As it all happens in slow motion, and I'm envisioning cab and blower damage, I made the decision to lift the blower, hit the left wheel brake and step on the forward pedal while turning left, as hard as I could (glad I went JD instead of Kubota so I could easily and quickly hit both pedals :laughing:). LUCKILY, the front tires spinning left brought the direction of travel away from the embankment and towards the lawn, missing the fence by a few inches. As the front left tire hit the grass, the tractor spun another 90 degrees across the road and came to a stop. After checking my shorts, I said a few words to the Man upstairs and hoped that I could drive up over the lawn back to the garage to put the tractor away ASAP! It climbed the icy grass with no problems, so I tucked it back in while questioning my sanity for attempting such a stunt. I was WAY to complacent on the icy surface, and I'm usually a fairly cautious person - not sure what got into me! (And yes, that is an extension cord that I forgot to unplug before heading down as well that goes to some Christmas lights. Fortunately, it just unplugged and was not damaged at all!)
Anyway, just wanted to share my experience and pictures of the tracks so that with any luck, the same situation will not happen to you! I'm not up on my chains, but maybe I should be looking at something good on ice but won't tear up the hot top driveway? Do they make such a thing??? Hindsight, I see where SO many things could have gone wrong and I was extremely lucky. Lesson learned! :ashamed:
Stay safe out there - plenty of winter left!
/ REMINDER - Ice is very slippery! #2
Yeah, you get used to dealing with that stuff here. If you had stomped on the hst pedal to go faster you can drive it out to get steering back and aim towards something safer. My snow removal route is along a valley, so half the driveways dump onto the road the others you get stuck in the peoples yards.
/ REMINDER - Ice is very slippery! #3
DMax, glad to hear that you are OK, ice is always a problem.
/ REMINDER - Ice is very slippery! #4
Glad to hear you are ok.
What you just described is the exact reason I got the Massey(left foot brake), with turfs and chains.
My paved driveway is steep, and deadends into a busy township road.
/ REMINDER - Ice is very slippery! #5
6 dead on the roads up here this weekend says volumes for the road conditions.
Yes, I'm afraid the entire region has had a tough time with this recent weather pattern...
/ REMINDER - Ice is very slippery! #7
You're likely the bravest man in the world. Michelle Kwan would shudder just looking at the desperate scratches in the ice.
Funny how such incidents are easy to recount in story but impossible to apply later in practice.
/ REMINDER - Ice is very slippery! #8
Need any help celebrating the outcome of that experence?
Absolutely! :thumbsup: Looking back at how many things could have gone wrong, it's truly amazing that the tractor still has all of its paint still where it belongs...
/ REMINDER - Ice is very slippery! #10
Experience is the best teacher. Lessons you don't forget.
/ REMINDER - Ice is very slippery! #11
Something similar happened to me about 4 years ago, We had a light bit of freezing rain, and I decided to take my 4WD Silverado to work instead of the company car. We live in Branson, Mo, and all you have is up hill and down hill. Even my drive way out of the garage is up hill. So I took off out of the garage forward ( I back in always) and got maybe 25 foot and the truck spun out and came back down the driveway sideways heading for the brick divider between the 2 garage doors the other one which was closed with a car behind that. The only thing that save this totally out of control pickup was that the overhang of the house is over 2 feet, and under the overhang there was no ice, just dry concrete. The sideways truck hit the concrete and stopped about a foot from the bricks. The wife came out with some kitty litter, and after about 15 minutes of see-sawing around we managed to get the truck back in to the garage undamaged.. we both breathed a sigh of relief and I got on the phone telling my boss that I wasn't coming to work today!.. lesson learned. Yeah ice is not fun at all:(
James K0UA
/ REMINDER - Ice is very slippery! #12
Maneuvering on ice can be hazardous indeed. The good part is that you were unscathed physically. Wet clay can get slippery also.
/ REMINDER - Ice is very slippery! #13
Now that is some compelling writing right there:thumbsup::thumbsup:
Glad you came out of it unscathed.
Ha ha - thanks guys! After reading k0ua's post, I remembered that I had this happen as well a few years back at my parents' house with the plow truck... Their house has a very steep driveway and without going into details, let me just say that I learned that day that dragging the plow on ice after you've started sliding does not slow you down! There were chainsaws and a wrecker involved, ending the night a few hours later without any damage to the truck and completely missing the entire Superbowl :mad:
/ REMINDER - Ice is very slippery! #15
Okay you can have the brakes on the JD. I outfitted my Kubota with the optional ejection seat. Fortunately I have not had to use it. All kidding aside good to hear no one was hurt
Ha ha - love it!!
/ REMINDER - Ice is very slippery! #17
Funny you'd bring this up, it's even worse when covered with water, as evidenced at 3:43. :laughing: Enjoy the rest of the video made today, while enjoying the January "thaw".
[ame=http://www.youtube.com/watch?v=ily3t7Zl_2Q&list=UUlYycXS0UgAJj5toKOqMhkg&index=1&feature=plcp]Playing on the pond - YouTube[/ame]
/ REMINDER - Ice is very slippery! #18
My property is hilly and ices up often. I've got an '84 chevy plowtruck with chains on all 4 wheels & a 4wd Yanmar with rear chains. I probably should chain the fronts also, so it doesn't wash out from under me. As they are, they're darn near unstopable. Get chains.
Another fine Go-Pro presentation, thanks Haymaker! Impressive riding across the ice while staying upright - for those of you that succeeded :thumbsup:
