Grapple Pin On Grapple
/ Pin On Grapple #1
buck12
Mississippi
Kubota 5460HSTC
I have been doing a little research on grapples. I really want a grapple for my Mahindra 2615 with a 106 loader. Problem is my tractor doesn't have the quick attach bucket and I really don't want to spend the money to convert it. I found where BamaRob added a Millonzi grapple to his 2615 in this thread http://www.tractorbynet.com/forums/attachments/98559-grapple-install.html It appears Millonzi is no longer around. Does anyone make a pin on grapple to fit my loader?
/ Pin On Grapple #2
WR Long claims to have the schematics for over 750 FEL's. Tried them?
/ Pin On Grapple #3
I have an ATI bolt on grapple. Fits a wide range of buckets. My bucket is 5'.
I couldnt make the link to Millonzi work so I dont know exactly what you want. Maybe something like the ATI will work for you.
/ Pin On Grapple #4
ANBO has one that will pin to my BX2660 - still thinking if I really need one. Have one of theirs (quick attach) on my L5740 - been very happy with it. They're expensive, but extremely well built - give them a call.
/ Pin On Grapple
I will check with long. Didn't see that when checking their web site. I was planning to use their kit for the hydraulics.
/ Pin On Grapple
I have been trying to decide between a bolt on grapple like yours and a dedicated grapple. It looks like your bolt on works well.
/ Pin On Grapple #8
It does. It is not as good as a dedicated unit but for me it was a good trade with my semi-perminent mount bucket. I did add some teeth to the grapple fingers to give it more bite. I cut some short pieces of 1/2" rebar and welded them on. You can see them in this picture I think.
/ Pin On Grapple #9
Unlimited Fabrication made mine pin-on. rootgrapple.com
/ Pin On Grapple #10
my Kubota was not QA so I added the Tach All quick connect system that converts the FEL to standard skid steer QA. Seems it costs about 6 or $700. It works pretty good, is not perfect but certainly decent. I have a Markham grapple and it is awesome, probably my most useful implement.
/ Pin On Grapple
Using the bolt on grapple is hard to see what you are picking up?
/ Pin On Grapple #12
I am sure the bolt on grapple has some uses and can be helpful but it in no way can do what a dedicated grapple can do, so it's not really comparing apples to apples. I use my grapple first and foremost in clearing land, ripping out small trees and saplings by uprooting them. There is no way I could do that with a bolt on. It just depends on what useage you need. ( I am not cutting down the bolt on as I am sure it works well for picking things up like those logs)
/ Pin On Grapple #13
It is hard to see. But it is no different than using the cutting edge of your bucket which you cant see either. After a while you get a feel for it and just know what angle and height your bucket has to be in to do what you want. Like I said, it is a trade off you have to make. It is plenty strong though. One of the big plusses for me is that I can go out to work and use either the bucket or grapple, switching back and forth as necessary. I have them both there and ready all the time.
/ Pin On Grapple
If THIS is your fel's bucket then THIS might be the just the ticket for you, perhaps powered with THIS. (Scroll to bottom, look at 700-5032-4080 )
The loader pictured has the quick attach. My loader does not have the quick attach.
/ Pin On Grapple
Per their web page the smallest grapple they make is 60". I think a 48" will meet my needs. I think I will email them anyway just to see if they have a smaller grapple that is not pictured.
/ Pin On Grapple
More research: I can buy a Wild Kat 48" econo grapple with no connectors and no quick attach hook ups for $500 plus shipping. If I go this route I will have to pay a fab shop to cut and weld brackets to work with my loader. Another option is a WR Long 48" grapple with the correct pin on plates for $1400. Any thoughts?
/ Pin On Grapple #17
Shouldn't cost much to get the plates welded on. If you get 'dual grapples' on your grapple, you can see between them when you're driving around, plus better grab-ability..
/ Pin On Grapple #18
It all depends on your mindset. The grapple is the greatest, it doesn't matter how you install one you will never regret it
[ame=http://www.youtube.com/watch?v=IAZNQ-tTUaA&feature=youtube_gdata_player]grapple vid 011 - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=oQXMcIXHVwQ&feature=youtube_gdata_player]tree removal 011 - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=4n6QpREP26Y&feature=youtube_gdata_player]Cutting Trees Along The Rail - YouTube[/ame]
/ Pin On Grapple
I ordered my 48" Wild Kat grapple today. Should ship early next week. I will start a thread with the install.
