IH Farmall Cub
/ IH Farmall Cub #1
Martian
Elite Member
Earth
Deere
So I've hijacked a couple threads talking about this one so I figured I'd finally start my own.
My great grandfather bought this new in 1951 (I believe I still have the receipt somewhere, it was crazy cheap compared to today) and now I inherit it. Great little machine to tote around and has definitely got its use through the years. Here's some pics, the first was taken yesterday, it's at my cabin so I snapped a pic while I was up there, and the rest are photocopies from during restoration, towards the end, I need to find when it was in bad shape pics, but it sure has come around.
/ IH Farmall Cub #2
Nice!!! Are you gonna use it? I have my great grandfathers too ,and I'm going to cultivate my garden with it. Give the old girl a job
/ IH Farmall Cub
Nah, don't really use it. Just toting it around now and then. If there's a light snow fall I'll use it sometimes. I have plenty of other machines not to get this one dirty if you know what I mean. It is surprising what it can do for a 13HP machine!
/ IH Farmall Cub #6
Outstanding..something about keeping yesterdays iron alive.
Bet your grandfather has big ole smile.
/ IH Farmall Cub #7
I still like pushing snow with my Cub Lo-Boy and mount a mower in the summer to groom our walking trails. I have an IH 4x8 trailer that came with the tractor when my FIL purchased it. I still use the Cub for hauling firewood and yard cleanup duty. It is an amazing little workhorse.
/ IH Farmall Cub #8
Nice Cub:thumbsup:
Mine is a 1948. Needs rings and valves (another winter project).
/ IH Farmall Cub #9
I sold my belly mower and got cultivators. Just rebuilt the carb and gonna do points, plugs and wires this winter.
I was looking on YouTube for cub stuff and found a guy talking about gaining power. Search "how to get more power in farmall cub tractors". Might try cleaning her insides up too. Anyway here's a pic. Since this pic I added two more shovels on front. Need two more for the rear now.
/ IH Farmall Cub #10
Hmm. I was almost positive I saw 13hp. Maybe 8PTO HP?
I think we may both be right!
http://www.atis.net/CubFAQ/cub_faq.html#q5
"When the cub was first introduced in 1947, it produced about 8.5 drawbar horsepower in the Nebraska tests, Test Number #386
Through the years there were a couple of changes to the engine, and later Cubs produced about 14 drawbar HP.
The changes that account for this HP increase were an increase in compression ratio, due to a piston change, and an increase in Idle, Max. speed to 1800 RPM, from the original 1600 RPM. There was also a change in the carburetor design, which may have affected the HP slightly. "
/ IH Farmall Cub #11
i have a front blade like that. do you have a belly mower for it. I believ emine is a ih 44" modle..
/ IH Farmall Cub
I do not have a belly although it would be really fun to mow with it.
Not nearly as many old toys as you, I just have the one oldy!
/ IH Farmall Cub #13
she looks great though.
mine is a 66, thus has the squareish tin, and was just after they went to OEM 12v.. etc. has battery ign as well.
/ IH Farmall Cub
Would you happen to have a pic?:D
It has been the most reliable tractor I've ever owned. It has started every single time I pull that one little lever(there's no key) - Except this one time I forgot to turn the gas on:eek:. I didn't think she was coming back, but a new starter later it is still the most reliable machine I've had.:thumbsup:
/ IH Farmall Cub #15
That blade can be mounted under the belly and does a great job of smoothing a gravel drive. But it is a bear removing the mower in the summer and putting the blade on, then putting the mower back on.
/ IH Farmall Cub
No quick attach back then!:laughing:
/ IH Farmall Cub #17
Actually, some Cubs had a one-point quick hitch on the rear, just nothing mid-point or on the front. I have a one-point plow and a rear blade. :)
/ IH Farmall Cub
I have that one point system. I've never used it or know how it works though:confused:
/ IH Farmall Cub #19
There is a one-point disc and plow on e-bay now - just search Cub one point. They just slipped into the slot on the back. There have also been discussions of them here.
BTW, I replaced the little hitch that is pinned under the one-point lift with a 2" receiver. I use that for a carry-all and to change trailer hitches in-out.
/ IH Farmall Cub #20
here's one..
