IH Farmall Cub
   / IH Farmall Cub #11
i have a front blade like that. do you have a belly mower for it. I believ emine is a ih 44" modle..
   / IH Farmall Cub
I do not have a belly although it would be really fun to mow with it.
Not nearly as many old toys as you, I just have the one oldy!
   / IH Farmall Cub #13
she looks great though.
mine is a 66, thus has the squareish tin, and was just after they went to OEM 12v.. etc. has battery ign as well.
   / IH Farmall Cub
Would you happen to have a pic?:D
It has been the most reliable tractor I've ever owned. It has started every single time I pull that one little lever(there's no key) - Except this one time I forgot to turn the gas on:eek:. I didn't think she was coming back, but a new starter later it is still the most reliable machine I've had.:thumbsup:
   / IH Farmall Cub #15
That blade can be mounted under the belly and does a great job of smoothing a gravel drive. But it is a bear removing the mower in the summer and putting the blade on, then putting the mower back on.
   / IH Farmall Cub
No quick attach back then!:laughing:
   / IH Farmall Cub #17
Actually, some Cubs had a one-point quick hitch on the rear, just nothing mid-point or on the front. I have a one-point plow and a rear blade. :)
   / IH Farmall Cub
I have that one point system. I've never used it or know how it works though:confused:
   / IH Farmall Cub #19
There is a one-point disc and plow on e-bay now - just search Cub one point. They just slipped into the slot on the back. There have also been discussions of them here.
BTW, I replaced the little hitch that is pinned under the one-point lift with a 2" receiver. I use that for a carry-all and to change trailer hitches in-out.
   / IH Farmall Cub #20
here's one..
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
15 FT Trailer (A50322)
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
2017 CATERPILLAR 259D SKID STEER (A51242)
2017 CATERPILLAR...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
