IH Farmall Cub
   / IH Farmall Cub #11
i have a front blade like that. do you have a belly mower for it. I believ emine is a ih 44" modle..
   / IH Farmall Cub
I do not have a belly although it would be really fun to mow with it.
Not nearly as many old toys as you, I just have the one oldy!
   / IH Farmall Cub #13
she looks great though.
mine is a 66, thus has the squareish tin, and was just after they went to OEM 12v.. etc. has battery ign as well.
   / IH Farmall Cub
Would you happen to have a pic?:D
It has been the most reliable tractor I've ever owned. It has started every single time I pull that one little lever(there's no key) - Except this one time I forgot to turn the gas on:eek:. I didn't think she was coming back, but a new starter later it is still the most reliable machine I've had.:thumbsup:
   / IH Farmall Cub #15
That blade can be mounted under the belly and does a great job of smoothing a gravel drive. But it is a bear removing the mower in the summer and putting the blade on, then putting the mower back on.
   / IH Farmall Cub
No quick attach back then!:laughing:
   / IH Farmall Cub #17
Actually, some Cubs had a one-point quick hitch on the rear, just nothing mid-point or on the front. I have a one-point plow and a rear blade. :)
   / IH Farmall Cub
I have that one point system. I've never used it or know how it works though:confused:
   / IH Farmall Cub #19
There is a one-point disc and plow on e-bay now - just search Cub one point. They just slipped into the slot on the back. There have also been discussions of them here.
BTW, I replaced the little hitch that is pinned under the one-point lift with a 2" receiver. I use that for a carry-all and to change trailer hitches in-out.
   / IH Farmall Cub #20
here's one..
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
(INOP) 2014 DEERE 210G LC EXCAVATOR (A51242)
(INOP) 2014 DEERE...
Alloway 1315 10"x61' Transport Auger (A50774)
Alloway 1315...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
UNUSED FUTURE FUEL TRANSFER PUMP (A51244)
UNUSED FUTURE FUEL...
1994 Toyota 6000lbs 2 Stage Forklift (A52128)
1994 Toyota...
