mattridessleds
Mattridessleds, just curious but do you think only one piece of angle (slotted piece) is enough to support the plow? I wonder if you might want to add one or two more pieces to add stability to your setup, which by the way you did a very nice job.
We'll see how it goes. That slotted piece is about 3/8 thick it is actually the old jack stand to the plow that got cut at the angle to make it fit there. Debated about just rigging up the chain like it would be on the plow if it was on a pickup but so far i used it the otherday to grade the driveway a little just for kicks and I like being able to move the plow in 6 directions and being able to put down pressure on it. The bottom is welded all the way around that rectangular metal piece I think it will hold up. If not i'll add some gussets or something later.
-matt
