Balast
/ Balast #1
pickeringchris
Gold Member
So I had the ck27 out for the first time today and played with the loader. With a full bucket of dirt she is a little bouncy.
Should I load the rear tires?
Thanks.
/ Balast #2
You are going to need balast in some form, for almost any use of your FEL. There are all sorts of great ideas on TBN threads - from balast boxes to loaded tires and lots of alternatives in between. Just browse the forums and look for key words relating to weights and balast. Have fun and enjoy TBN.
/ Balast #3
You might get mixed answers here Chris. Some will say that rear ballast is better for transferring load off the front axle. Loaded tires definitely stabalize the tractor but can leave all loader weight pivoting on the front axle.
I loaded my rears and have lifted to the limit of my loader without getting light in the back end, and have no extra ballast.
The dealer was pretty confident that I couldn't overload the front axle on the CK20. Your model CK27 has a greater lift capacity than my CK20 so you might want to load tires AND add rear ballast. Especially since the pumpkins are your focus and those heavy lifts will be common.
/ Balast #4
I would load them, its a bit of cheap insurance against a roll over and you'll have that extra stability even with something light on the 3ph.
Even better is to set the rear track a bit wider as well but if your lot is all level then it may not be worth the trouble.
I've got my tractor set to the widest possible and the rears loaded with rimguard and it allows me to go more places while using the loader.
/ Balast
I just found a place that I can get sugar beet juice. I can put a tote in my trailer and they will fill it up.
Does anyone know how many gallons my rear tires will need? Thanks
/ Balast
You know, the more I think about it the more I think I should just make a concrete 3ph ballast. That way she is not so heavy when I need to trailer her. I have a ABS drum that would be perfect.
I will make it 5-600 lbs.
/ Balast #7
On my DK45 I leave the mower or bush hog on the 3PH unless I'm working in tight spaces. That extra 600 lb way out on the back provides a lot of counter balance for a full bucket. But loaded tires (have those too) also help improve stability against roll-over. I can't speak to CK specifically.
/ Balast
I'm like an old lady on this guys. Stability is not an issue because my half acre ranch is flat. :). Still I am thinking I will need the extra weight in the tires for traction when I use a subsoiler. Maybe I do need both the tires filled and a 3ph weight.
/ Balast #9
Unless your worried about soil compaction, I don't think you'll ever be sorry you've loaded the tires and have a counter weight for loader work.
I only have 7' blade for a counter weight now and I should really get something much heavier even though I'm only using maybe half the loaders capacity.
/ Balast #10
I'm definitely in the load your tires camp. I love the weight for traction and putting the hp to the ground. Even then, you might want a counter weight if the pumpkins stick way out beyond the bucket (and I'm sure they will).
Check with a dealer on how much fluid exactly. I'd guess about 35 - 40 gallons per tire for R4s. R1's hold less, I think.
/ Balast
I found a chart online that said 29 gallons for my tires. :)
If I can lift a pumpkin with my machine it will be a pretty disappointing season. I have a tripod that loads the pumpkins on the trailer anyways. My loader will be used for moving manure. :)
/ Balast #12
Kioti recommends 700 pounds rear ballast.
KIOTI - run ahead of the pack!
If you plan to trailer the tractor much I would not load the tires. That's a lot of extra weight to trailer around. You'll be amazed how much traction you have just by engaging 4 wheel drive. Loading the tires does not eliminate the need for rear ballast.
Don
/ Balast #13
Chris,
So how much do the pumpkins typically weight?
/ Balast
2011 was my second year growing giants. In 2010 my best was 1030lbs. Pretty good for a beginner. This year I was plagued by bad luck and my best was 1065 lbs. really disappointing considering I had one split the first week of August at 930lbs and was doing about 30lbs per day. It was on target for 14-1500lbs :-(
Btw for the guys that ad wiper fluid for ballast do you have tube or tubeless tires??? I know wiper fluid does have some corrosion inhibitors.....
/ Balast #15
That was my thinking as well.. Took an old home made steel safe, cut the lid off, used 3" square tubing to make attachment points for the 3pt, filled it with iron ore rocks.. Works GREAT, and I can simply drop it when I dont need it...
I had originally thought of loading the tires with antifreeze, but decided against it due to concerns over getting tire service with the antifreeze, and not being able to drop the weight when moving it...
/ Balast #16
Chris I did both, load the tires and built ballast barrel. But I don't trailer. but when you are pulling that subsoiler, you would appreciate the loaded tires. especially with the R4 tires. and the ballast box is not going to do you any good off the tractor. So my recommendation is to do both, if you can stand the extra weight on the trailer. If you do this you will notice a big change in stability for the better, and push/pull of the tractor will be far greater than a "bare" tractor.
James K0UA
/ Balast
Thanks James. Thats what I was thinking. With the subsoiler I can't have a ballast box so the loaded tires will be golden. I just ordered a fill valve. Probably won't be here till the new year.
Looks like I will only get 250-300 lbs per tire according to the chart I found online that says 29 gallons per tire.
Don, each pumpkin gets 30' x 30'. I grow 4. They are a lot of work. Then I have regular pumpkins and other stuff I just let grow wild.
/ Balast
FYI. I don't own a trailer big enough to move the tractor nor do I have a vehicle to pull it. So the trailering thing will be a non issue for a while. At least a year or 2.
/ Balast #20
What I was curious about was the size (xx feet by xx feet) of the actual planting area. I'm trying to visualize the area and pattern the subsoiler will need to follow.
Here in Michigan I've seen pumpkin fields that have individual sheds built over each of the large pumpkins.
Don
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2011 Jeep Grand Cherokee Laredo SUV (A64557)
2011 Jeep Grand...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2016 JEEP PATROIT (A67148)
2016 JEEP PATROIT...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A64557)
2010 Mercury 15HP...
