My Bucket modifications
/ My Bucket modifications #21
That bucket looks fantastic! Well done...
/ My Bucket modifications #22
Anyone have an idea on how to strengthen the cutting blade up without adding a tooth bar. A friend has asked me to weld up some stiffener to his bucket that had cracks in the back. His front lip is bowed up from back dragging. He does a lot of prep work for foundations (contractor) with the NH TC40 and 10 years of backdragging has a pretty big bow in the middle. Without cutting out the old blade and welding in a new one, anyone got some way to keep a smooth edge on it and make it stouter.
/ My Bucket modifications #23
Shouldn't be to difficult to straighten the front edge, then weld a plate on the bottom or the top of the existing cutting edge, not sure which would be better, but that should stiffen it up considerably.
JB
/ My Bucket modifications #25
Great job. How are you planning on using the receiver mount? I'm puzzled by how you would use it to move trailers with the height it is at. Not criticizing, just trying to figure it out. Thanks.
/ My Bucket modifications #26
They make numinous sizes of drop and raise 2" receiver hitches to fit whatever your needs may be...
/ My Bucket modifications #27
Of course. I should have thought of that.
I haven't had a use for it yet, but the mount was cheap and it is bolt on. Just figured someday it might come in handy, if not no big expense to it.
/ My Bucket modifications #29
Those mods look great and make the bucket a lot stronger.
/ My Bucket modifications #30
I use mine almost every day, you'll find uses for it.
JB
/ My Bucket modifications #31
You did all the things I needed to do to mine. I have the after pics if you use the bucket hard without the additions. The top is bent up and side edges folded over. My brother was giving me a hard time about the bucket and I told him I bought it to use and it has done the required job well!
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
John Deere XUV825E (A61307)
John Deere XUV825E...
1980 FORD A66 WHEEL LOADER (INOPERABLE) (A63569)
1980 FORD A66...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
