My Bucket modifications
/ My Bucket modifications #21
That bucket looks fantastic! Well done...
/ My Bucket modifications #22
Anyone have an idea on how to strengthen the cutting blade up without adding a tooth bar. A friend has asked me to weld up some stiffener to his bucket that had cracks in the back. His front lip is bowed up from back dragging. He does a lot of prep work for foundations (contractor) with the NH TC40 and 10 years of backdragging has a pretty big bow in the middle. Without cutting out the old blade and welding in a new one, anyone got some way to keep a smooth edge on it and make it stouter.
/ My Bucket modifications #23
Shouldn't be to difficult to straighten the front edge, then weld a plate on the bottom or the top of the existing cutting edge, not sure which would be better, but that should stiffen it up considerably.
JB
/ My Bucket modifications #25
Great job. How are you planning on using the receiver mount? I'm puzzled by how you would use it to move trailers with the height it is at. Not criticizing, just trying to figure it out. Thanks.
/ My Bucket modifications #26
They make numinous sizes of drop and raise 2" receiver hitches to fit whatever your needs may be...
/ My Bucket modifications #27
Of course. I should have thought of that.
I haven't had a use for it yet, but the mount was cheap and it is bolt on. Just figured someday it might come in handy, if not no big expense to it.
/ My Bucket modifications #29
Those mods look great and make the bucket a lot stronger.
/ My Bucket modifications #30
I use mine almost every day, you'll find uses for it.
JB
/ My Bucket modifications #31
You did all the things I needed to do to mine. I have the after pics if you use the bucket hard without the additions. The top is bent up and side edges folded over. My brother was giving me a hard time about the bucket and I told him I bought it to use and it has done the required job well!
2007 FRAC TANK 500BBL WHEELED (A63569)
2007 FRAC TANK...
207283 (A52708)
207283 (A52708)
New Holland TC35D Tractor w/ Loader (A64047)
New Holland TC35D...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
