Backhoe BH77 broke - defective part?
   / BH77 broke - defective part?
Well, I got the backhoe back earlier this week with the pin and boom replaced...but unfortunetly, I haven't had a chance to try it out again yet. With the forcasts calling for rain over the next week or so, it may be a while before I get the chance. :(
I have a new L3800 and BH77 and after digging out a small stump this morning I found the boom lock would not engage and had to push on the backhoe to get it locked. Looking at the pin in question here I can see that the frame sides are slightly bent and the holes out of alignment. There is also more pin showing between the frames. I am assuming at this point the pin has broken and will call my dealer tomorrow.
I have put about 5 hours on the backhoe digging out stumps and some rocks. I saw this thread after purchasing but before delivery and while it made me nervous, my dealer assured me he would take care of any problems if they occurred. Now I just hope I don't see him too often.
Hope your dealer resolves your BH problems w/o issue. Mine has been repaired :thumbsup: but I have no way of knowing if the pin they used to repair it is flawed like the original. Time will tell I suppose...just hope that if it snaps again, it's still under warrenty.
   / BH77 broke - defective part? #73
My dealer just called me, regarding my newish L3800HST. He says there is a mandatory recall out for the BH77 pin!
edit to clarify: I hadn't complained about the pin; mine is working fine. They called me out of the blue.
- Mike
- Mike
Good to hear...My dealer says they used the "new" pin when i asked about the repair...but he never mentioned the mandatory recall. I don't know how I would ever know if they used the new pin or not unless it breaks again. Hopefully nobody else will have the broken pin issue on the BH77 now.
It's been so wet around hear that I still haven't had a chance to try my repaired backhoe out yet. I'll be sure to post here again with an update after I've dug a few holes.
   / BH77 broke - defective part? #75
I also have the "new" pin and have used the backhoe a bit since being repaired but nothing that would put much strain on it. I am very happy with my dealers handling of the problem (they picked up the backhoe within 30 minutes of me calling and had it back a few days later) and now with Kubota putting out a mandatory recall I am more confident that I made the right choice when buying.
Good news! ...I finally had a chance to get out and work with the backhoe this weekend and it dug a bunch of holes without issue. I can't say that the thought of breaking another pin is gone...so, I'm using some extra care with it but it's amazing what this little thing can do.
   / BH77 broke - defective part? #78
This post is a little late, but I thought I would throw it in for whoever reads it.
I had a recall on my BH77 backhoe attachment due to a faulty pin that had to be replaced. The dealer said the factory was recalling due to defective pins breaking in half. It was fortunate for me that backhoe was in shop for a cylinder replacement at time of recall. My brand new backhoe came up with a defective cylinder out of the blue, and made me lose the machine for two weeks until they could figure out it was the cylinder and not a valve. All is fixed and now I am up and running strong again digging stumps here in NC clay!
   / BH77 broke - defective part? #79
Never too late to add good info....:)
   / BH77 broke - defective part? #80
My 30 hour L3700 SU with a BH77 just broke the said pin. This is the second time I have used the BH. I called my dealer and they said they will have somebody come pick it up and repair it. I hope they fix the bent ears as well. This blows.
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
