Backhoe BH77 broke - defective part?
   / BH77 broke - defective part? #101
Hello,
I take delivery of my new L3800 w/BH77 tomorrow and wish to identify exactly what pin I should quiz my dealer about. Can someone please show me a pic, or describe its location?
Thank you,
   / BH77 broke - defective part? #102
Hello,
Thank you,
There is an image included in the very first post of this thread that points to the pin.
   / BH77 broke - defective part? #103
All,
I checked with my dealer and there IS a mandatory campaign on this PIN.
Affected Serial numbers are A0005 thru A1209
Just wanted to share the info I received.
   / BH77 broke - defective part? #104
I 2nd this comment.
Which rubber pads are you referring to?
Nevermind, you are talking about the stabilizer pads. If you are planning on using the backhoe on pavement, or blacktop, or just for storage on a concrete floor, I would recommend the pads so you don't screw up your driveway or garage floor.
   / BH77 broke - defective part? #105
All,
Birdman,
The serial numbers you provided are for the backhoe pin issue, right?
Thanks fellow Vermonter!
   / BH77 broke - defective part? #106
Birdman,
Yup.....that range of serial numbers is affected by the 'weak pin' bulletin.
   / BH77 broke - defective part? #107
Yes I was talking about the stabilizer pads. And thanks for the info!
Now i just have worry about that dang pin.
   / BH77 broke - defective part? #108
I just bought my BH77 in OCT last year and the serial number is way outta the range affected by this PIN (mine is A2xxx), so there is a high probability that you will be OK once you receive yours as well.
Anyone can have a backhoe that has been sitting in inventory for a long time and there is a chance that you do get one in between A0005 thru A1209, but my gut is telling me you are most likely going to be ok.
   / BH77 broke - defective part? #109
Nice! My new BH77 is a A2.... Did I tell ya it's coming tomorrow???
   / BH77 broke - defective part? #110
All I can say is ouch. And I was going to buy the 77. I just bought an L3200 and planned on getting the hoe this winter. This may change my plans entirely. A hoe that breaks pins that easily is just not something I can deal with. Way too much hard work here for it to survive.
I sure hope you get it resplved to where you are both happy with the resolution and confident in your machine.
Good luck friend.
   / BH77 broke - defective part? #111
aginn,
I wouldn't worry about the pin issue preventing you from a BH77 purchase as the thread is pretty old. At the time I was purchasing one and postponed the order a few months until the issue was cleared up. My serial number starts in the A3's well past the issue numbers and it is almost two years old. Since then I have not read of any issues with that model BH. Dig away!
   / BH77 broke - defective part? #112
Did anyone figure out the factory fix.....was it a harder pin? or longer pin with retainers on the outside?
   / BH77 broke - defective part? #113
I bought a new Kubota, L3301DT with a loader and backhoe, BH77 in Jan of this year. I've broke three pins (7K503-23160) during this year and the last one Nov 5th. When the pin broke it flanged out the upper ears as it has done in the previous breaks. I pulled the ears back with a c-clamp so that I can reinsert the new pin. After a few hours of use, the pin recedes into the pin's hole approx 3/16". I called Kubota and they will pick up the hoe and determine what is causing the problem. I believe the pin is too small and that the ears are not reinforced with a support. Additionally, as it was mentioned in the thread, the other side should have a retainer to preclude it from flanging out if the pin breaks. Do you think that I need a pin and a new boom and cylinders since it has been fixed three times or should I ask for a new hoe? I don't want a repeat of this after the warranty is over. Any comments?
   / BH77 broke - defective part? #114
Wow I just bought a used BH77 2 months ago with serial 162? and thought I was good. This is saying something is not correct yet. Thanks for all the info guys I will continue to read. I will check mine as soon as the rain stops.
   / BH77 broke - defective part? #115
TwinCam88 this is not pointed at you:
I have to throw the BS card on the link posted to the broken bh77.
Look at the wear on the bucket. There is no way you can wear the paint off a Kubota bucket in 3 hours of use.
Then look at picture of the 3200 in his heated garage. That picture is PhotoShopped:ashamed:.
This quote is from way back April 2011. There is no doubt at all that this photo has been altered. Just look at the tractor - it is "floating" above the floor which has been obviously "wiped" especially in front of the rear tire. Also notice the odd striping on the floor under the front. Lots of scurrying around with the edit brush all over the floor. The prospective distance between the tractor and the garage door is too short to have a BH in there. The BH looks small in the photo whereas the garage surroundings tell another story. Is this the type of damage with twisting of the side tongues which results from pushing sideways with the boom?
   / BH77 broke - defective part? #116
Yeah, you're right, my bucket looks similar to the one in the photo, after much digging in rocky soil. 3 hours? Sweeping sideways is a bad practice with light equipment, but there are situations (backfilling a trench) where it just saves a ton of time.
   / BH77 broke - defective part? #117
I broke the pin in my BH77. It had very few hours on it at the time. If I remember, maybe 5-6. Digging a pine stump and it broke. Made a mess out of the ears on the dipper. It was replaced under warranty and so far no issues. I have also not really used it that often. 2 weeks ago it worked harder than it ever has ripping out granite curbing in a parking lot. It survived that.
   / BH77 broke - defective part? #118
Anyone else had any issues? My friend has a BH77 serial # A0539 and his pin broke.
   / BH77 broke - defective part? #119
I know this is an old thread, But I recently broke the pin holding the curl cylinder to the arm, Messicks had it in stock for about $30. I got two just in case this was common, I have never broke a loader pin in 25 years of loader operations. My L48 is a 2007 model, so this is old news I guess. I found rust all the way through the pin where it broke, it seemed to be a fractured not a clean straight break, the retaining bolt kept half of it in, so thankfully no accident and no one got hurt.
MrC.
   / BH77 broke - defective part? #120
I haven't read this whole tread but things do happen. Batches of steel can have flaws. I have replaced the pins that hold the FEL bucket on my BX several times. They fracture right across the pin at the inside bushing edge. Those things once; I buy two so there is a spare on hand. Since I put the QH on the FEL that problem seems to have stopped.
Ron
2004 John Deere 4720 (A60462)
2004 John Deere...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
2014 Freightliner 105' Bucket Truck (A61306)
2014 Freightliner...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
