Backhoe BH77 broke - defective part?
   / BH77 broke - defective part? #101
Hello,
I take delivery of my new L3800 w/BH77 tomorrow and wish to identify exactly what pin I should quiz my dealer about. Can someone please show me a pic, or describe its location?
Thank you,
   / BH77 broke - defective part? #102
Hello,
Thank you,
There is an image included in the very first post of this thread that points to the pin.
   / BH77 broke - defective part? #103
All,
I checked with my dealer and there IS a mandatory campaign on this PIN.
Affected Serial numbers are A0005 thru A1209
Just wanted to share the info I received.
   / BH77 broke - defective part? #104
I 2nd this comment.
Which rubber pads are you referring to?
Nevermind, you are talking about the stabilizer pads. If you are planning on using the backhoe on pavement, or blacktop, or just for storage on a concrete floor, I would recommend the pads so you don't screw up your driveway or garage floor.
   / BH77 broke - defective part? #105
All,
Birdman,
The serial numbers you provided are for the backhoe pin issue, right?
Thanks fellow Vermonter!
   / BH77 broke - defective part? #106
Birdman,
Yup.....that range of serial numbers is affected by the 'weak pin' bulletin.
   / BH77 broke - defective part? #107
Yes I was talking about the stabilizer pads. And thanks for the info!
Now i just have worry about that dang pin.
   / BH77 broke - defective part? #108
I just bought my BH77 in OCT last year and the serial number is way outta the range affected by this PIN (mine is A2xxx), so there is a high probability that you will be OK once you receive yours as well.
Anyone can have a backhoe that has been sitting in inventory for a long time and there is a chance that you do get one in between A0005 thru A1209, but my gut is telling me you are most likely going to be ok.
   / BH77 broke - defective part? #109
Nice! My new BH77 is a A2.... Did I tell ya it's coming tomorrow???
   / BH77 broke - defective part? #110
All I can say is ouch. And I was going to buy the 77. I just bought an L3200 and planned on getting the hoe this winter. This may change my plans entirely. A hoe that breaks pins that easily is just not something I can deal with. Way too much hard work here for it to survive.
I sure hope you get it resplved to where you are both happy with the resolution and confident in your machine.
Good luck friend.
(10) UNUSED SDLANCH 2.5CM X 3.5M RATCHET STRAPS (A58375)
(10) UNUSED...
Giyi Telescopic Boom (A57149)
Giyi Telescopic...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
(4) Master Craft 235/65R17 Tires With Rims (A55272)
(4) Master Craft...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
