Wood splitting tools
   / Wood splitting tools #1
pennwalk
Lancaster PA
Yanmar 186D
I don't split a lot of wood but now and then I do a little light splitting. I have a sledge hammer and a couple of wedges and a maul. I have seen axes with splitting aids formed into the head. Do any of those work? Do mauls need to be sharpened from time to time?
Chris
   / Wood splitting tools #2
I allways used just a simple splitting maul, the trick is to slighty turn it has it hits the wood. This will cause the wood to split instead of just sticking the maul into the block. It does take a little practice but makes a 100% difference.
   / Wood splitting tools #4
Mauls are supposed to be dull. I like an 8 lb-er for splitting used one for many years. But, I also like the Fiskars Super Splitter. This is a different concept than the maul. With the maul I usually go for the middle and put some umpfh behind my swing. With the Fiskars I can swing nice and easy and aim between the middle and the edge of the round, working my way around the center, then after it's whittled down spit the center.The thing is almost effortless and it is very sharp... requires sharpening periodicity and use of gloves. Also the handle is dang near Motor7 proof which is quite an accomplishment;)
Now I reach for the Fiskars much more than the 'ole 8 lb-er.
[ame=http://www.amazon.com/Fiskars-7854-X25-28-Inch-Splitting/dp/B00004SD7B]Amazon.com: Fiskars 7854 X25 28-Inch Splitting Axe: Patio, Lawn & Garden[/ame]
   / Wood splitting tools #5
I now have a Collins 6lb maul, 36" handle. The whole handle slides through the head so I haven't managed to break it yet, other plastic handle designs have the handle and head "glued" together, which lasts a cord or 3 for me... I had an 8lb maul but I split better with the 6lb'er
I'm tempted to try the 36" fiskars splitting axe though, I split on the ground and previous short handles would end up in my leg eventually... A lighter head can allow you to actually put more energy into the swing, like an aluminum bat vs. a solid wood one. I'm also tempted to try reducing the weight of my current maul by grinding off the back but maybe that will affect its balance?
If I can't split it with the maul after a few swings I set it aside and when I get a few stubborn chunks saved up, I just rip them in half with my 372. Cutting with the grain goes fast even in hard maple or oak.
   / Wood splitting tools #6
Wood grenade works wonders.
[ame=http://www.amazon.com/Olympia-Tools-65-504-Patented-Splitting/dp/B00002N801]Amazon.com: Olympia Tools 65-504 Wood Grenade Patented Diamond Shape Splitting Wedge: Home Improvement[/ame]
   / Wood splitting tools #7
Bought a Fiskars 36" from Amazon. It works too good, bought the 28" to go with it.
Amazon is the cheapest place, no tax and free shipping.
Now I have 5 old axes and 2 new ones. Fiskar is the answer.
Joe H
   / Wood splitting tools #8
I have two splitting mauls, sledges, wedges, a thing the looks like a dent puller with a wedge on the bottom and a a 22 ton hydraulic unit. When I was splitting by hand I found the mauls worked best slightly dull and with a fiberglass handle. Having read about the Fiskars on here I might be tempted to try it but the other stuff already takes up a lot of room in my workshop :eek:
   / Wood splitting tools #9
Whatever tool one uses, they ALL work better with the occasional application of beer. . .
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
Landoll Hauloll (A52128)
Landoll Hauloll...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
