Toplink Extending a hydraulic top link
/ Extending a hydraulic top link #1
tpulley
Wake Foest NC
Kioti DK45SE
I went to the local ASC office today and bought a cat 1 hydraulic top link, hoses and fittings.
I put all the pieces together and boy is this sweet. My only concern is I really want two or so inches of travel more from it. Other than going to their cat 2 that gives me the two inches any suggestions how I can get there.
Terry
/ Extending a hydraulic top link #2
If you don't weld yourself, take it to a welding shop and have them cut off the ball on the tractor side (cylinder end) and weld in a 2" or 3" piece of the same size metal to the cylinder end. Then weld the ball back onto that.
They may even weld in a heavier piece because it would take the side forces even better.
You must have a Pat's Easy Change. I did the same thing on another tractor before getting the "insert" style Pat's on the M7040.
That's a good idea. I do weld some, but I don't have anything to cut it with, well... maybe its soft enough to cut with a hack saw. I will poke around and look for some extra metal.
/ Extending a hydraulic top link #4
A hacksaw will work or maybe a Sawsall with a metal cutting blade. Be sure to grind an angle on the weld areas to get 100% penetration. Like this: >< Make several passes alternating on both sides to prevent warping.
You don't want it coming apart at an awkward moment.
Oh, and their Cat 2 hydraulic top link can be bushed to Cat 1 if you want to go that route. It is a little heavier duty, also.
/ Extending a hydraulic top link #6
Terry
Do you want it 2 or so inches longer, or 2 or so inches more travel? NOTHING that you do will get you ANY more travel. If you want more travel you need to get a different top link. ;)
/ Extending a hydraulic top link #7
MtnViewRanc is right. The extension is only moving the starting point. If the stroke is OK the extension will work. If you make a threaded extension, it could be variable.
It is more correct to say I need to move the starting point as opposed to changing the stroke. The first 3-4 inches or so are not being used right now.
Allen in TX has the exact idea I want to accomplish. I am now looking around for the rod/pipe to make the extension.
I am thinking my mig welder should work. What do you guys think?
/ Extending a hydraulic top link #9
so good luck for you! :)
/ Extending a hydraulic top link #10
It depends on how the shaft end is configured now.
>If it is a piece of thick flat bar then splice it with the same.
>If it is round, splice it with round as did Allen in TX.
>If you can get away with not cutting the ball flush to the cylinder it would be easier and stronger to splice in a matching piece with a 100% weld.
Personally, I would not use MIG. It will stick it together but penetration is limited with the heavier materials.
It will take a (open) root pass and several cover passes on both sides of the spliced shaft. This is best done with stick.
/ Extending a hydraulic top link #11
Really sort of depends on the size of his MIG. ;) A typical home owner unit would not be the thing to use.
/ Extending a hydraulic top link #12
To the OP, tpulley:
After you decide what you want to do you might want to run it by the guys in the "Welding Forum" on TBN. Lots of farmer/weldors over there.
/ Extending a hydraulic top link #13
To the OP, tpulley:
Very smart thing to do. Great suggestion. :thumbsup:
/ Extending a hydraulic top link #14
we do that kind of thing here also, I weld on the cylinders and help out people who want to extend there cylinders
/ Extending a hydraulic top link #15
Just a guess on my part but the Op probably wouldn't be going through any of this if he had done business with either of the last two posters! MtnViewRanch/CarterandCarter
2022 John Deere DR16 Planter (A63111)
2022 John Deere...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2019 CAT 259D (A60462)
2015Ford Escape SUV (A61574)
2015Ford Escape...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
