DIY forks
/ DIY forks #1
stick welder
none
I looked at the price of attachments for my machine and decided to build a few of my own. I have built a receiver plate, mini backhoe and am working on forks.
/ DIY forks #2
Nice
I have a toro dingo. Very similar in general style and I really like it. I had used it at a community garden and knew its capabilities. So when I started looking for a tractor of my own. I had a couple of wheeled tractors come out 4 trials. Even at 10 horsepower more they could not compete. The little track guys are more maneuverable and had a better hydraulics the only thing I don't have for mine is a mower. Are you using anything?
Again nice.
Bob
/ DIY forks
I have never used a mower with one. The Ditch Witch has realy large lugs on the tracks and tends to tear up the ground in a few passes, the skid turning doesn't help either.
/ DIY forks #4
I built some bucket forks for my last tractor and modified them to fit my nerw one. Made of channel iron, I used them mostly for lifting logs and I found I could bend them. I stiffened them near the short end by welding in more channel, upside down, into the bottoms. With that lesson learned, I built my new log forks to not bend, using lots of reinforcement where it matters, at the start of them. I posted picks of my log fork build on this thread: (I didn't get the pics up until four pages in.)
http://www.tractorbynet.com/forums/build-yourself/213676-log-forks.html#post2441799
Stick welder? Yup.
/ DIY forks
The channel forks are just gusseted right now but, I plan on reinforcing them similar to the idea mentioned above by boxing them in. So far they seem to hold quite a bit of weight without too much flex. I have been using my old lincon electric ac/ dc arc for my projects, it takes a little more time than a mig but has produced reasonable results.
/ DIY forks #6
You, sir, are too modest.:thumbsup:
/ DIY forks #7
Stick Welder,
You did a nice job making your forks. Here's a set I made for my old tractor, and they held 1000 lbs of logs with no problem. I'm sure yours will serve you well.
/ DIY forks #8
Stick Welder,
Yes, both sets are nicely engineered. I will be eventually making some moveable forks and will be looking at these again. I bent my first set because I found I would try to move anything that got in the way. I don't think I've gotten over that inclination.
/ DIY forks #9
I made my forks from channel and though I use them on the 3 pt. for now, they have proven more than strong enough. I lifted my lathe in the crate and that was over 1000 lbs. I had a hard time keeping the front of the tractor on the ground for steerage. My point being that the channel will work very well. I hot bent the channel, reinforced, and boxed, but no gussets. Love it. Build thread is in signature.
Mike
Cub Cadet Ultima ZT1 Zero Turn Mower (A64047)
Cub Cadet Ultima...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
John Deere 4960 Tractor (A64047)
John Deere 4960...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2020 John Deere 6120M (A62180)
2020 John Deere...
