18x24 carport on slab? or pole building?
/ 18x24 carport on slab? or pole building? #11
I desperately need a place to start storing some stuff and am on a seriously tight budget. I was thinking about pouring a slab and having one of those $700 steel carports put on it for now, with the idea of eventually adding walls.
should I consider a pole building instead? I know I'm going to hit ledge in some spots a couple feet down.
I'd appreciate anyones experience along these lines.
Here's my 20x36 ft carport at the end of my gravel driveway. Sides are 9ft tall.
Carport was about $2700. I did the footings myself--there's about 6 yards of concrete in the footings at $100/yard plus cost of the rebar, forms, etc.
I paid extra for the side-draining roof option. I'll probably put sides on it one of these days.
/ 18x24 carport on slab? or pole building? #12
dont know what kind of a budget your on, but personally where i live (Idaho) I see those portable sheds either collapse or blow apart in the winters here.
Keep in mind, Grs, that in other states a strong wind is what we'd call a gentle breeze. Also, in other states the snow that falls in November doesn't stay until April.
flusher, is that a concrete footer that runs along the ground?
/ 18x24 carport on slab? or pole building? #14
Yep, about 12" wide and 18 to 24" deep (because of the ground slope), 36 feet long. Had to do that to satisfy county building code for a structure this size. No ground augers allowed.
I suppose I should check about code here. That may have some impact on my decision
/ 18x24 carport on slab? or pole building? #16
around here we can get away with non permitted 'ag' structures if it has no power or water and land is A-1
/ 18x24 carport on slab? or pole building? #17
Here in Idaho, no portable structure needs a permit. If it is stuck into concrete and over 200 SF...permit time.
/ 18x24 carport on slab? or pole building? #18
The only permit I needed when I built my house in Arkansas was a sewer permit. Perhaps if I had a bank loan or something, they would have wanted some additional inspections but the county was happy with the sewer. When I put in a sprinkler system, the county wanted inspection to assure I had a backflow preventer in place. That is about the extent of county requirements. I dont live in an incorporated area so no city regs to follow.
/ 18x24 carport on slab? or pole building? #19
You might look at the 8x8x20 or 8x8x40 steel containers. You can also find the 8x9x40 containers. With a little bit of fabrication to replace end door with a roll-up and framing in a walk-through you'd have a respectable shop. Price is usually less than $3000 for the 40ft units. I've seen them converted into many different style offices/barns etc.
Good luck.
yes I'm leaning toward just using gravel under a steel carport for now. I really could use a flat slab for welding and assembly projects but it'll have to wait.
What happens to these steel buildings when they're just bolted to a driveway with no footer?
HYUNDAI HL955 WHEEL LOADER (A62129)
HYUNDAI HL955...
2019 Chevrolet Tahoe SUV (A60352)
2019 Chevrolet...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2025 AGT Industrial MX-MRW14 (A60463)
2025 AGT...
