Anyone load their front tires?
/ Anyone load their front tires? #1
hrcarver
Gold Member
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
I know (almost) everyone loads the rears. Anyone load the fronts on the mfwd's? Looks a easy way to pick up a couple hundred lbs (far cheaper than 2 more suitcase weights), but the tire guy I asked thought I was nuts.
Make any difference with a load hanging on the 3pt?
/ Anyone load their front tires? #2
I do on the 7520 Ags. Adds about 500 lbs without exra load on the axles like front chassis weights would. Very nice for FEL work cuz tires dont squat as much. Better digging force too. I just use water from the garden hose so no issues to drain or vary loading.
larry
/ Anyone load their front tires? #3
I have all four tires loaded on both my Mahindra's. The 3215HST and the 7520. I don't know about the difference of having the fronts loaded or not. I filled all four to start with. When doing dirt work, the more weight that you have the better and quicker it gets done.
Just my :2cents:
/ Anyone load their front tires? #4
I have thought about this over the years. The front tires turn slightly faster than the rear do. Loading the front tires supposedly increases wear in the axle.
I may add a little to the tires, as I am out of space on my weight rack.
/ Anyone load their front tires? #5
there was a good tread on just this topic! Search
(How much weight would loading the fronts of B2920 add )
:thumbsup: :thumbsup: :thumbsup:
/ Anyone load their front tires? #6
I just buy enough tractor and don't load squat. If you have enough arse behind the bucket, loaded tires aren't necessary.........
Because of what I use my tractors for, loaded tires are a big no. Compaction on forage ground decreases production and yields. I hardly ever use 4wd though both my units are 4wd. Lets say for 'just in case'.
/ Anyone load their front tires? #7
So bigger tractor that weighs more is better than smaller tractor with loaded tires? I would think that no matter how it is configured, weight is weight.
I guess I need to be taken to school.
Does it matter to the ground how the weight is configured on a tractor?
/ Anyone load their front tires? #8
Mikeee If I remember correctly 5030 is a big hay producer, so his needs are mostly pto hp driven not ground traction,
its a comprimise a smaller loaded tractor can do more with better traction than a non loaded smaller weight traction.
Not everyone needs extra weight, I unloaded my Ford 600 rears since it no longer does any tillage only rotary cutting. My new 5740 still experminting to determine if I need the rears loaded.
/ Anyone load their front tires? #9
On my L3010 Kubota say "do not load the front tires". But they give no explanation. Does anyone know why they make this statement ? Is it safty at high speed road operation or mechanical considerations ? Seems like a good idea in a lot of situations.
/ Anyone load their front tires? #10
My owners manual on my Kubota L4400 indicates not to load the front tires with fluid. I read somewhere that the fluid filling of the front doesnt allow enough room for the air to act as a shock absorber causing front end damage. I will also add my buddy has a Kioti had the fronts loaded and his front rim busted the cent out. Did the fluid in the tires cause it? Who knows.
/ Anyone load their front tires? #11
All that I know is that after about 6 years and 6-7 hundred hours I have not noticed ANYTHING negative about having the fronts filled. Obviously other peoples experiences may vary.
As far as having a big enough tractor so that you don't need to fill the tires, what happens when you need the weight, but there is NO room for that bigger tractor.
Everyone's wants and needs are very different, all of us need to try and remember that. ;)
/ Anyone load their front tires? #12
much more wear on the axle from weight on the rack
larry
/ Anyone load their front tires? #13
Ditto at near 1000hrs hard use filled 90%+.
larry
/ Anyone load their front tires? #14
School is in session.....
Absolutely. Weight and tire loading as it pertains to tractive effort is directly attributable to compaction of the ground under the tires and to crop damage.
That's why track tractors are getting popular. The per square inch of loading is much less but the tractive effort is raised because there is more contact with the ground.
Besides, at speed, track machines ride much better, cross no-tilled headlands perpindicular to crop rows without spilling your beverage or loosening your teeth.:)
The downside to a track machine is replacement cost of the tracks and turning ability. Again, I'd never load any tire because it causes damage to the crop I harvest. I would actually prefer a less agressive tire than the Ag1 because the lug penetration on an Ag1 tire even not weighted is more than a comparable conventional tread tire. However, I do use my tractors for utility work so it's a matter of being cognizant about how I put the power to the ground and why I buy my tractors with 4wd, not that I engege the front drives much. I don't believe I've ever traction locked the rear or the front.
If I need additional traction, I simply drop a range on the main box. Large tractors come equipped with slippage indicators that actually calculate tire slippage in tillage operations. My friends Case Magnum FWA has an on board, real time digital slippage indicator that alerts him if the ground speed versus wheel revolutions isn't consistent. At that point he can either engage the differential ,locks or set his draft control to a shallower depth.
While my Kubota's are capable of tillage on a limited scale, most owners never see or need concentrated tillage requirements.
/ Anyone load their front tires? #15
5030, while you make valid points, I believe that the OP was asking the question pertaining to a 60-70 HP machine. Maybe not & I have just misunderstood, but that is the size that he is looking at. :confused3:
/ Anyone load their front tires? #16
If the fronts are foamed, the front drive breaks more often. I have proven this to myself. I learned not to work the front drive too hard in the woods, driving over anything that gets in the way at sharp turning angles. I've popped the cages off the front wheel bearings more than once. I can't say that liquid fills would be the same.
That's true. I didn't realize the size mattered.
/ Anyone load their front tires? #18
Size doesn't really matter, what matters is what you are doing with the machine. I have seen 600hp + machines and they had weighted them down as heavy as they could get them.
Depending on the task, A smaller heavier machine will do as much or more than a bigger machine that does not weigh as much. Conditions and circumstances make a HUGE difference with how a machine needs to be set up. ;)
/ Anyone load their front tires? #19
Hi, I didn't load my fronts because the Kubota guys said not to. But they didn't say why not. I'm not all that concerned with damage to my hay crop, and I do like traction, so I may still do it anyways. It seems to me that in my Ag Eng classes back in university they said something about needing some tire slippage to get maximum traction. We had to calculate what percent slippage was ideal for different tractors/tires/loading. I know that sounds odd, and would definitely damage a sod crop, but I've seen it in action in many tractor pulls.
Bye for now,
Troy
/ Anyone load their front tires? #20
Have to agree with 5030's original point about having enough tractor for what you are doing. Loading the front's will gain, what, another 5% in pulling power? If that last 5% is necessary just to get your work done with any level of frequency, one could argue you need more tractor to begin with. Kind of like putting chains on all four tires so you can go through the mud or snow. I did that a few times on a Jeep in younger days. Made it seem unstoppable but played heck with the drivetrain. But every owner gets to decide for themselves if more weight (or chains) is a good idea for their situation.
Caterpillar 973/977 Traxcavator Parts and Service Manuals (A63117)
Caterpillar...
Cab Cam Monitor (A63117)
Cab Cam Monitor...
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
Caterpillar 12H/140H/160H Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2012 Ford Expedition SUV (A61574)
2012 Ford...
