Anyone load their front tires?
   / Anyone load their front tires? #1
hrcarver
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
I know (almost) everyone loads the rears. Anyone load the fronts on the mfwd's? Looks a easy way to pick up a couple hundred lbs (far cheaper than 2 more suitcase weights), but the tire guy I asked thought I was nuts.
Make any difference with a load hanging on the 3pt?
   / Anyone load their front tires? #2
I do on the 7520 Ags. Adds about 500 lbs without exra load on the axles like front chassis weights would. Very nice for FEL work cuz tires dont squat as much. Better digging force too. I just use water from the garden hose so no issues to drain or vary loading.
larry
   / Anyone load their front tires? #3
I have all four tires loaded on both my Mahindra's. The 3215HST and the 7520. I don't know about the difference of having the fronts loaded or not. I filled all four to start with. When doing dirt work, the more weight that you have the better and quicker it gets done.
Just my :2cents:
   / Anyone load their front tires? #4
I have thought about this over the years. The front tires turn slightly faster than the rear do. Loading the front tires supposedly increases wear in the axle.
I may add a little to the tires, as I am out of space on my weight rack.
   / Anyone load their front tires? #5
there was a good tread on just this topic! Search
(How much weight would loading the fronts of B2920 add )
:thumbsup: :thumbsup: :thumbsup:
   / Anyone load their front tires? #6
I just buy enough tractor and don't load squat. If you have enough arse behind the bucket, loaded tires aren't necessary.........
Because of what I use my tractors for, loaded tires are a big no. Compaction on forage ground decreases production and yields. I hardly ever use 4wd though both my units are 4wd. Lets say for 'just in case'.
   / Anyone load their front tires? #7
So bigger tractor that weighs more is better than smaller tractor with loaded tires? I would think that no matter how it is configured, weight is weight.
I guess I need to be taken to school.
Does it matter to the ground how the weight is configured on a tractor?
   / Anyone load their front tires? #8
Mikeee If I remember correctly 5030 is a big hay producer, so his needs are mostly pto hp driven not ground traction,
its a comprimise a smaller loaded tractor can do more with better traction than a non loaded smaller weight traction.
Not everyone needs extra weight, I unloaded my Ford 600 rears since it no longer does any tillage only rotary cutting. My new 5740 still experminting to determine if I need the rears loaded.
   / Anyone load their front tires? #9
On my L3010 Kubota say "do not load the front tires". But they give no explanation. Does anyone know why they make this statement ? Is it safty at high speed road operation or mechanical considerations ? Seems like a good idea in a lot of situations.
   / Anyone load their front tires? #10
My owners manual on my Kubota L4400 indicates not to load the front tires with fluid. I read somewhere that the fluid filling of the front doesnt allow enough room for the air to act as a shock absorber causing front end damage. I will also add my buddy has a Kioti had the fronts loaded and his front rim busted the cent out. Did the fluid in the tires cause it? Who knows.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2017 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2017 GENIE GS-1930...
2005 TerraGator 8104 (A53473)
2005 TerraGator...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
